This is a high-quality, efficient brushless electronic speed control with an integrated switch-mode BEC. It can operate without the need for a separate receiver battery to power your servos and receivers, saving you weight and complication. GECKO series also include ESC OPTO for giant flying. This series of ESCs also features an exposed, finned heat sink aluminum case with lightweight plastic for Rc airplane end caps. Additional features include safe power arming along with advanced programmable, data logging system, low voltage cutoff, braking, timing, throttle input range, and more, making this series truly a pro series speed control.
As the development of the electronic and popular demand of the market, our BEC has been specifically designed for extreme aerobatics and therefore has the capability to support the higher current applications to eliminate the possibility of unwanted shutdowns, and is also capable of supporting continuous simultaneous multiple servo operations typically found in CCPM equipped hardcore 3D E-helicopters.
Features
Data logging system such as temperature, voltage, current, RPM,
SBEC Voltage Output 5.0, 6.0, 7.4, 8.4V adjustable
Advanced Governor Mode and soft start
High SBEC Current Output, continuous 8A and burst 16A, designed to meet your high current application
Power arm protection, over-heat protection, low-voltage protection and lost-signal protection
Secondary sub-menu setting by LCD program card or PC interface
Firmware updating by PC interface
Unique metal shape designing gives your new fashion visual impact.
Super smooth and accurate throttle linearity
Support and match with most of the motors, including high RPM motors
Programmable motor timing
Utilizes new smaller MOSFET technology to minimize weight
Finned heat sink
programmable throttle input range
Anti-spark circuit eliminates (HV OPTO version only)
Specifications
Output: Continuous Current 150A ,Burst Current 180A for 10 seconds
Battery : 18-38 NiXX / 6-12S LiPo
Weight: 120g
More info: http://www.ztwshop.com
Comment by Mateusz Sadowski on March 8, 2018 at 1:03am
The size of those blades and the lack of protection make me feel really uneasy!
Comment by FMS RC airplane on March 8, 2018 at 6:53pm
Mateusz Sadowski
you can have a try, it is big drone and Strong Power  for the motor
fly very slow,low.and saft.
Comment by lot on March 9, 2018 at 5:18am
Without propeller protection can be everything except safe!
Comment
