I've been away from the diydrones scene for a while, but I'm still around. Here is something that I can contribute to the community.
This is my tutorial on how I configure my FrSky Taranis to allow flight mode changes to be displayed on the Taranis screen as well as spoken out loud.
- SB+ Manual Mode
- SB FBWA
- SB- AUTO MODES Selected by SA
- SA+ LOITER
- SA AUTO TUNE
- SA- AUTO
Setup as listed
L1
AND Switch: FM3
L7
L8
Special functions
autotune (Auto Tune)
loiter (Loiter)
fbw (Fly By Wire)
armlo (Arm Loiter)
armauto (Arm Auto)
armat (Arm Auto Tune)
When using the OpenTX Speaker app, make sure the file names are under 8 characters, and with out spaces. The phrases can be spaced out how ever you like it to speak.
SF1
Function: Play Track
Value: normal
Repeat 1x
SF2
Switch: L2
Value: fbw
Repeat 1x
Value: loiter
Repeat 1x
Value: autotune
Repeat 1x
Value: auto
Repeat 1x
Switch: L6
Value: armlo
Repeat 1x
Value: armat
Repeat 1x
Value: armauto
Repeat 1x
Your FrSky Taranis should now be talking and displaying flight modes on its display. Next it's time to setup the MIXER, which will control the output of your Flight Mode channel (I use CH5, but this could be any CH)
Mixer settings
The setup for the mixer takes the current Flight Mode and uses it to drive CH5 to a specific PWM value.
First start out with CH5 MIX. Edit this and use the following:
CH5 (FM1 MIX)
Yes the names are all "nor", this is why COPY is dangerous |
Source: MAX
Weight: 100
Modes: 1 (MAKE SURE ONLY FM1)
Then add one for FM2
CH5 (FM2 MIX)
Source: MAX
Weight: 40
Modes: 2
and FM3
CH5 (FM3 MIX)
Source: Max
Weight: 10
Modes: 3
FM4
CH5 (FM4 MIX)
Source: MAX
Weight: -20
Modes: 4
FM5
CH5 (FM5 MIX)
Source: MAX
Weight: -40
Modes: 5
Final Steps are to open APM Mission Planner and setup each flight mode, if you use a different mode, dont forget to change the names in used in this guide, as well as the OpenTX Speaker files.
Nice write up, one suggestion: I wouldn't use the "add" mix for changing flight modes. "Replace" is a better choice.
I can attach my taranis config if anyone wants it for a template..
Thx, I have learned a new way to program flight modes on the Taranis.
