How to DIY a ground station
3689501985?profile=original
Well first of all I'll start with the reason I chose to build this ground station instead of using a laptop
So after many times of carrying the laptop around assembling and disassembling parts and cables xbees usb cables and such I figured my laptop days as ground station will be numbered
Because of this I decided that I needed a ground station that would save me the need to deal with the assembling and disassembling in the field and will be more durable then my laptop
First I had to plan my shopping and inventory list
I had an old laptop with a broken screen that did not survive its frequent trips around and my poor handling skills And an older laptop screen that i planned on using with the other laptop mother board in order to do it I had to buy a lcd adapter that will let me use the vga port on the motherboard with the lvds laptop screen
That's about what I had to start with
The second thing was to look for a case that will be large enough to contain the mother board the screen another small screen that will fit in the remaining space and some lcd meters for giving a better look mostly and some 3 position switches
After many searches I found an old stock of Pelican at an affordable price and size that is suitable for my budget and needs i measured the space that left after installing the main screen and figure out that a 5 inch screen will just fit
3689502061?profile=original
then i needed to think of a way to install everything in a way that would give me easy access to the parts just for any case
3689502089?profile=original
after trying multiple materials Plexiglas plywood and others which are not very easy to work with without machinery which i didnt have access to i found just what i needed a pvc foam it is not the perfect material consider his toughness which is lacking but it is very easy to work with and so i chose it and start to cut holes and install the switches and lcds
3689502006?profile=original
for the finishing touch of the station i used a vinyl sticker in a 3d carbon woven pattern which gave the panel a nicer look
3689502162?profile=original
some technical details:
for powering the station i chose to use a sla battery instead of lipo for some reasons
first it is easier to deal with in terms of charging it and is much safer then lipo
second it is cheaper and heavier so I can save money and use it for balancing the case
i also wanted to be able to hook the station to ac power when its available
so i searched for some ac/dc converter that will meet my power demends and it turned out that i missed it in my calculation by a bit but for the moment it is working and i see no reason to change it but when it brake i'll certenly buy a bigger one capable of outputing more current
I then wanted to charge the battery while using the ac/dc convertor and giving the station more reliability i found a charger which is also a ups that is just what i wished for
also used step up regulator from 12v to 19v for powering the motherboard
and a step down regulator from 12v to 5v for powering the usb hub
both regulators are adjustable with lcd meters for convenience reasons and capable of outputting more current than consumed
bom for the station is:
laptop mother board and screen - free
pelican 1520 - ebay
LCD Controller Board DIY Kit - for connecting lvds screen to the motherboard - ebay
VGA 2AV driver board 5inch HSD050IDW1 800×480 screen - ebay
12v to 19v step up convertor with lcd for powering the motherboard - ebay
temperature meter with two sensors (inside and out of the case) - ebay
power meter with 2X lcd voltmeter and amp meter - ebay
12v to 5v step down convertor with lcd for powering usb hub - ebay
picoUPS-120 12v dc micro ups system - ebay
4X 3 position 6 pins switches - bought at a local electricity store - ebay
4X Delta Fan for Compaq 12vdc .15A 40mm EFB0412HHA - ebay
3d carbon woven pvc vinyl sticker - deal extreme
ac/dc convertor 100-240v input 12v output 3.2A or higher :) - ebay
pvc foam sheet - ebay
access point modem asus wl-330ge - ebay
usb hub 7-ports - ebay *
thermal skin for wires - ebay
I didn't really traced every buy that I made for the station but roughly everything sums for less then 400$ in total
- ebay is not the cheapest by any mean
* if you want to build your own usb hub you can do it using fe1.1s chip or similar very easily
**and so on with the other regulators it is just to my believe cheaper and faster to order it assembled :)
features of the station:
up to 2.5 hours of use on a single 12v 7Ah sla battery
secondary screen switchable between av and vga (via pc hdmi port and vga converter)
wireless connection to antenna tracker (xbee repeater, Bluetooth, 5.8Ghz)
access point modem - for multiple connection to the station (andropilot for ex)
can be easily modified and upgraded
sorry for my poor writing and description capabilities/skills
3689502031?profile=original3689502181?profile=original
the uav station is not complete yet still need to do some more things so I will update the post as It go
  • almost final design
    3692640241?profile=original
    hopefully I could finish it by the end of the month and post a new complete post
    things on my to do list :
    program the arduino for full power control the station meters and lcd (searching for a vfd or other lcd long and narrow for installing at the top of the bottom panel to show all parameters and arduino options)
    program the arduino as hid for the serial joystick to talk with the autopilots programs more easily
    thinking on where to stuck the usb hub
    finish to mount everything and glue the 3d carbon sticker for a nicer look
  • so the utile shop near my house has a shortage of the pvc foam I use for building the bottom part of the station
    hence I started to work with some of the to do list I now don't have much time to work since I started my school
    that to say I've added a picture of the joystick that will control the camera pan and tilt and will be installed in the station
    3692626220?profile=original
    it is a ch product hfx 2 axis with button
    the other servo programed to tilt the joystick 90 degrees down or up when push button is pressed
    hopefully i'll have some time and will get some pvc foam to work with this weekend so I will post more photos
    http://youtu.be/w8gFWcsHZLA
  • Very neat set up. I'm envious!
  • uav ground control station bottom update pictures
    3692617227?profile=original3692617120?profile=original3692617147?profile=original3692617355?profile=original
  • tecnically creative
  • I made a mistake the switches is actually 2 position 6 pins which switches between on and off
    it is not really a major mistake it is just cheaper I think and there is no real use of the third position
    I made a quick temp rough sketch of the power schematics3692615090?profile=original
  • multiple inputs 2xAV and VGA and its going to output video or secondary vga 800x480  (via laptop hdmi port to vga digital to analog converter)
    What a small blue screen on right?
  • @ R_Lefebvre you can use a mini keyboard with integrated mouse that is what i'm planning just waiting for the keyboard to arrive check it and post a picture and the sla is 7Ah so 7000mAh it is also used to balance the case and is much simpler to charge safer and cheaper so no reason not to use it
    3692614747?profile=original
  • Very nice, I am going to do this.
