HD video for UAV's
3689522281?profile=originalI keep asking myself why this cannot be done, and so far i have not found an answer i can believe. So i bought a commercial HD Video/Audio sender for home use and plugged in my gopro as a video source, and my flat screen TV as the player, and i connected up these devices and viola..! it worked. So my next thought what is the problem with making this work in a UAV , it is using 5.8Ghz it is cheap to buy, just need to hack it so the antenna is less directional, and we can then have HD in our goggles, or on our screen.
This would be far more preferable to me for a first time FPV flyer as the picture is so poor at 480x240 pixels, you can hardly see if your moving or not.
What do you all think? i know a more elegant solution would be nicer but for now it would work.
sample of what i meant : http://www.maplin.co.uk/wireless-hdmi-video-sender-kit-503801
  • The Nyrius ARIES has a range of 30 feet with line of sight. Good luck with that.
  • What about this product? http://www.shoptronics.com/nyrius-aries-npcs550-wireless-hdmi-trans...
    that is found on this forum:http://forum.blackmagicdesign.com/viewtopic.php?f=4&t=3706
    I would have bought it for a test, but i cant find any one that ships to Norway. Can any one help me?
  • that looks good, I like it too, you could install that into a groundstation easily enough
  • Okay Tommy; I will do the same.  Thanks.
  • @Andy: I'm not ordering from that link. I sent an email to the supplier and got a sample device price 76USD.
    She also sent me tha datasheet/manual in pdf format.
  • @Tommy
    That looks interesting.  If you don't mind, are you ordering from that link and what are they charging you?  Thanks.
  • I have already ordered this device: http://www.alibaba.com/product-gs/878661072/H_264_1CH_WIFI_IP_Video...
    I will remove the case because of weight.
  • Thanks Charles.  Getting there but not as compact as I would like (the form factor you showed earlier from Zowietek is perfect).  Someone pointed out Cavium earlier and I am contacting them to see what is possible.  I will post any feedback received.
  • something like this?
    http://www.liveu.tv/LU40i.html
  • Yeah; unfortunately not the portable solution I need.  I did send a message to see if they have something in the pipeline.  Thanks for the feedback.
