I love my Spektrum Dx7 and my 2.4Ghz JR XPS9303 and i refused to trade its solid rock performance by a 72mhz radio just to increase range of my FPV/UAV. So in collaboration with my friend JB we find out the cheapest and secure way to amplify the signal, it even works in some Futabas and virtually with any 2.4Ghz radio, but some modifications are required. Lets see some options:-Spektrum Dx7 this is the cheapest solution for a very reliable 2.4Ghz radio, i used it for about a year and i never had any signal glitch (unless i fly beyond 2000 feet). The problem with this one is that you have to modify it, you need a SMD to U.FL adapter, drill a hole in the side of your radio and just connect and screw the adapter, no soldering required. If you have more than 5 hours of experience with Legos your qualified to do this job. Then you just need to connect the booster. The one in the picture (middle) is already modified.-If you have the awesome JR radio but is 72Mhz you can buy the Spektrum 2.4Ghz module and just insert it in the back of your TX, personally this is my favorite setup. It's a good deal because includes a $99 dlls receiver for free! Note that JR TX alone cost around $600 dlls, but you can get it for less, i got mine for 300 bucks with Spektrum Module included on R/C Groups =P. Remember you are looking for the JR XPS9303.If you have one of the fallowing Futaba radios:7U Series Radios8U Series Radios8J Series Radios9C Series Radios9Z Series RadiosFN Series RadiosYou can just go and buy the Spektrum 2.4Ghz module, easy and with no hassles. It's also a good deal because includes a $99 dlls receiver for free!
One of the advantages of the Spektrum receivers is the build in diversity system, you can even buy one with 4 satellites like this one, or buy a super tiny, tiny setup like this one, or the traditional one.The diversity is crucial to have a reliable link when you are flying far away, also Spektrum has a receiver for Carbon Fiber airplanes (Carbon Fiber blocks RF signals).The idea is to have the best reliable hardware with an SMA connector and the SMA extension cable, after that you are ready for the final step: Get an amplifier. But we are talking about a few hundred dollars here, if you get the weakest one of 100mW it will cost you around $150 dlls. This is not pocket friendly in my point of view. So again our Asians friends come to the rescue, after making some research around the net I've found on eBay and a home Wireless Amplifier, so i decided to give it a chance and i bought it for 60 bucks including shipping! Wow that's a good deal! The one i got is this one.Note that the amplifier needs 6Volts to work, you can get a cheap 6V power regulator from here and just make the adapter. A 3 Cell LIPO is enough to supply it for a long time.
After receiving the AMP i did some tests, here are my results:Before using the amplifier, i was able to fly around 3000 feet away (~1 km) using a 900Mhz@500mW Video transmitter. I never lost the video signal, only the radio link...Using a 1.3Ghz@1Watt Video transmitter i was unable to fly more than 2000 feet away (~600meters). So the 1.3Ghz Video transmitter reduces my 2.4Ghz Spektrum range...Then i got my cheap Asian amplifier and using a 2.4Ghz Patch Antenna i was able to fly around 2.6 miles (4.18Km) away without a single glitch, but i was unable to continue because now my video was causing me problems, hehe!Not bad at all! Honestly i don't need more than 2 miles of coverage, is really a long way for an EasyStar. In conclusion the maximum range for my setup still unknown, but the range achieved is more that 2.6 miles and the +2 extra miles of coverage gained for less than $100 dlls is really a good deal for me!
Now just remember this:-The range will be different in other setups.-Never turn on your radio without antenna.-Never turn on the Amplifier without antenna.-Note that in some country's this amplifier may be illegal.Thanks for watching!
  • Make sure that your receiver for your airplane is turned on or the green led on the booster wont turn on.
  • Is there a way to check the amp? or is the LED the amp checker :)
  • well the plug in supply they came with says input of .35a but output 6v 2000mh so that's two amps. I thought that was the issue but I just plugged in power from the one on my Speckrum which is rated at 5 amps but no luck. Would powering it up with too little voltage ruin the amp?
    Check data sheet that came with your amp it should state the amps needed.
  • hmmm - my ParkBEC is rate for continues 1.25 amps 1.5a 60 second burst. I don't know about watts sorry.
    I just did a range check with the power down settings on the futaba and the antenuator removed and got 40 paces.
    Interesting thought about the BEC.
    Is your 6v esc rated for current requirements of 1 watt amp?
  • I have tried that several times - I have even tried a spare battery so I could have two different power sources.
    Thanks for commenting and trying to help. I am at a loss...
    Try this, turn on booster , then Futaba 7c...
  • after reading the info about the 1 watt booster from drone - I am starting to wonder if even with the 6db attenuator if the futaba 7c puts out to much for the booster? The manual for the booster states no more than 15dbm. Maybe that is why I got the green light for a few seconds and it went off for good.
  • Well, all is not easy . .
    I successfully have a DX6i boosted with the 500mw booster and the green light stays on nicely. Thanks for all the help here BTW.
    I installed a newly received 1 watt booster from Drone and installed it on my Futabu 7C and do not get the green light (had it for a few seconds only).
    (1) I have checked and 6 volt is getting to the booster from the BEC.
    (2) I have a 6db attenuator installed as on booth the DX6i and the Futaba (Thanks for the help finding that info here also).
    The green light on back of the Futaba showing it is transmitting is on and steady and it connects to the receiver with no problem. But I do not have a green light on the booster. Any ideas how to check any further?
    Thanks for the help. Here are a few pics of the installation.
