3689603275?profile=originalDroidPlanner has just been updated with an incredible feature that comes very close to "one-button 3D mapping" with ArduCopter. Here's a quick tutorial on how to use it to create a mission that autonomously takes off, circles a building taking pictures of it and lands, capturing all the imagery you need to stitch together a 3D model like the above. This model was taken with a 3DR Iris and GoPro camera in just one circle and stitched together with Autodesk Memento/ReCap.
You can see some 360-degree rotatable examples here and here. For best results, click the little cube box at bottom left and pick "Shadeless" for the rendering options.
(Don't forget you can now do this via Bluetooth with your Android phone or tablet, in addition to the usual 3DR long-distance radios.)
Steps
1) In the Edit screen, hold down the trash can icon, which will clear any previous mission you had and auto-create the first waypoint, which is an auto-takeoff. Then tap the Add Waypoint button (the top one with the "+") and tap the center of the structure you want to 3D-map:
3689603302?profile=original
2) Tap on that new waypoint and in the drop-down menu, select "Circle". This will tell the copter to do a single circle at the default altitude (20m) and the default radius (10m), with the nose of the copter and camera always facing into the center of the circle. If that's what you want, you're done!
3689603183?profile=original3) (Optional) If you want it do to do multiple circles at the same altitude, change the "Orbits" number in the menu below. If you want it to do multiple circles at different altitudes (to give the stitching software a range of views), tap on Advanced and change the Steps number to the number of circles you want, with the Altitude Step being how much higher each circle should be over the one before:
3689603329?profile=original4) At that point, you can either launch the mission and when it's done it will loiter, waiting for you to manually land, or you can add more more waypoint to autoland (triangle waypoint icon below). If you're done, don't forget to press Send Mission to send it to the copter!
3689603404?profile=original
5) If you want the copter to circle with a larger or smaller radius, select Parameters
3689603356?profile=original
In the Parameters list, scroll down to CIRCLE_RADIUS and change it whatever value you'd like. (Note that in the screenshot below there's an error: the units are in centimeters, not meters. So 2000 is 2000cm or 20m. That will be fixed in the next push)
3689603198?profile=original
When you're done changing that, remember to Write the parameters to the copter:
3689603429?profile=original
6) Now that you've finished the mission, set your onboard camera to take a picture once per second in stop-motion or "intervelometer" mode (I use a GoPro Black with my Iris, which works great, but you can use any camera that has this mode). Don't forget to start the camera!
7) Now switch your copter to Auto mode and nudge the throttle up a bit. The copter will take off, fly to the structure, circle it at the altitude and number of times you selected, and automatically return and land at your feet! Mission accomplished!
Some safety notes:
  • Watch out for trees and other obstacles! Make sure your first circle is above any trees or other things that might be in the path of the circle
  • Make sure your radius is at least twice the distance from the center to the edge of the structure. You want to have at least ten meters clearance from the structure at all times
  • If you're doing an autolanding, make sure you've got plenty of room for the landing and no obstructions on the route home. If you can't ensure that, do the landing manually.
  • Don't plan any mission where your view of the copter will be obscured. You must be able to take over manual control if it looks like your mission will take the copter into harm's way
Stitching
Once you've finished the mission and acquired the imagery, you'll need to use stitching software or a cloud service to turn it into a 3D model. Autodesk offers some good free choices for that:
  • 123D Catch. Quick and dirty. This won't make the best model, but it's easy, works most of the time, and has a good web viewer so you can share the 3D model with anyone.  Mac, Windows or Web
  • ReCap 360: This offers better renders, but it can be hard to get it to reliably generate a model. Web
  • Memento: This is beta software, but it works great for me and is my go-to tool for high-quality renders and a very easy-to-use interface.  You have to join the Autodesk Labs program to use it (that's free and open to all), but it's well worth it for this gem. The only downside is that it's Windows-only so if you're a Mac user like me you have to dual-boot or run Windows in a VM
Coming soon...
In the next version of DroidPlanner, the interface to change the altitude, radius of the circle and the number and step-distance of each orbit will be improved to a simple "point and drag" feature, which is very intuitive. Basically, you'll just point at the structure you want to 3D map, drag the circle so it's well outside the structure, drag a slider for the altitude and press go. One-button mapping!
  • Amazing!
    This feature will works for fixed-wings, also?
  • Tried today again, was able to orbit 5 locations and RTL with no problems using my Nexus 7, not sure what kind of problem you might be having with your Nexus or radio. That seems odd. Be sure and let us know what you figure out. I would suspect the radio though. I continually get 100-90% flying around my 20 acres.
  • Thanks for the info Chris.  Just tried it again and Droid Planner says my link is at 100% and I get say 76% or 82 % before the downloading parameters just stop.  Guess I'll have to wait for the next build...
    Great update team!
    Would be fun to have an option to set the camera to either point to center (default) point outside (makes interesting shots) or follow flight path...
    Todd, I haven't had any trouble with that, but I always do it with a strong link. Arthur tells me that it's dependent on link quality. In the current build, it restarts the loading from the start if it has a problem, which is suboptimal, but in the next build it will just reload any parameter that didn't come in properly.
  • Can't wait to try this.  Nice job everyone.
    Last several times I tried to get my parameters from Droid Planner 2 it timed out.
    I have never been able to get parameters using my Nexus 7 tablet.
    Has this been fixed recently?
  • Very nice guys!
  • 100KM
    Hi Chris, I am new to DP but I am very impress with this apps. I think you are right, now even the original DP altitude is relative. Just a few weeks ago when I use my Samsung Note 10.1 with DP, it show absolute altitude in HUD. Today I try it with my ponepad7, most of the time it say disconnected but somehow I do manage a few successful connection and I notice the altitude shown is 0. Because of the disconnected problem, I can not confirm if it is relative altitude by checking the waypoint file in Mission Planner. Last time all mission build by DP with the absolute box check.
    Keeyen: No fear, DP 2 will extend to planes and rovers soon, but can you explain the point about relative altitude a bit more I can pass that on. All the DP altitude is relative already. Did you mean "absolute"?
    You can always post enhancement requests and bug reports in the Issue Tracker here.
  • This is going straight into my bookmarks, can't wait to try it.
