How to mod a Multiplex EasyStar
I was reminded by the Pict'Earth guys last weekend that one of the best all-purpose planes for carrying cameras, GPS recorders and any other sort of equipment you want to test is the Multiplex EasyStar, a virtually unbreakable powered glider. Because it's made of elastopore foam you can carve out the equipment compartment to carry pretty much anything you want, and the same foam protects everything in case of a "hard landing".
EasyStars are available for $54 without the radio equipment. This post is just a quickie to show you what else you'll need top make them good UAV platforms.
Although the kit comes with a brushed motor, I suggest you upgrade to a brushless so you can carry heavier loads with ease. This motor is a perfect fit and has power to spare. I matched it with this ESC. As always, you'll want Li-Ion batteries if you can afford them. An 11.1v, 2200 mAh pack will allow you to fly for more than half an hour under power. A 6x4 prop fits perfectly
For a radio, almost anything with six channels or more will do. The EasyStar has compartments pre-cut for servos; the HITec HS81s fit them best.
Finally, here's an important point. With the more powerful brushless motor, you'll find that rudder is really too small to be effective. You need to make it bigger to increase its "authority", which both helps in more extreme moves and at slow speed. The easiest way is to glue or double-sided-tape two business cards to the rudder. Here's a picture of one such mod (I didn't bother to trim mine as neatly as this guy did):
Once you've done all that you can shove all manners of cameras and such in the equipment area. If you don't want to carve holes in the bottom, you can always just bolt a camera to a bit of wood and strap it to the top, like this.
  • Turning the prop about face will not work, you could reverse the motor but it would probably be very very inefficient aerodynamically. For the relatively small cost, just buy a suitable pusher prop!
    Regards
    D
    @Andre B.
    Some prop manufacturers suggest moving down 2 sizes when going to 3 blade, others do not.
    It only stands to reason that you are able to move more air with the 3 blade vs. 2 blade.
  • @AndreB -- I used a 3 blade prop on the advice of Jason Short, because of the sound ("bzzzzzzz" vs "wopwopwop")
    http://diydrones.com/profiles/blogs/multiplex-easy-star-uas
    http://www.diydrones.com/profiles/blogs/my-ardupilot-projects-status
    It's the biggest prop you can stick on the EasyStar without cutting the tail off or moving the motor mount.  I think the prop size is maximized for extra lift with a large payload.  The throttle doesn't have to be on "full power", and the motor power is also a factor.
    Basically, I copied some recommendations and took some advice.
    -J
  • @AndreB - I'm also building an EasyStar drone.  According to some suggestions I used a 6x4 3-blade pusher prop (Tower) and a 2200kev motor (HK).  As a total newbie I did not know I needed something to mount the prop, but I eventually bought a Great Planes Collet Prop Adapter 3.175mm to 5mm (Tower).  It seems to be mounted okay, but I have not yet flown.
    FWIW,
    -John
    Welcome Jeremy! Great to see you here...let me know how it goes. Happy to help if you run into any issues.
  • What's the best place to buy this in the US? I can't find it for ~$50
  • Thanks for the answer Chris. However, will it work better with added ailerons?
    @PatrickD: No. The IMU can work with rudder-only, too.
  • Hi,
    Do we need to add ailerons for the easystar for it to work with the new ardumega+oilpan?
    Thanks,
    Patrick
  • Tim,
    Try these for all things Multiplex in the UK http://www.modelspot.com/kit-only-9-c.asp
    The standard kit for many Multiplex models includes a brushed motor.
    Peter
