Interactive Checklists (Proposal)
3689552331?profile=original
Every now and then a new blog post or forum thread pops up something along the lines of "Be careful, I got cut by the propeller ..." with ugly images attached.
UAVs are complex solutions and can be dangerous. The technology itself can help prevent accidents but eventually in most cases it boils down to human errors. I have fond memories sitting in a cockpit while going through checklists. We should learn from the real aviation and adopt checklists to make flying UAVs safer. I am always going through my checklist on paper before a flight. This is a proven approach to keep risks low.
In our situation we could take the idea of paper checklists even one step further: interactive checklists. It would be even nicer if the groundstation software would aid the operator going through the checks. The GCS could help by displaying relevant values which need to be checked and allow user input where needed in a structured ways, step by step.
The Image above shows a mockup of a tablet base UI which could be used as checklist in the field. If such a feature would be implemented in DroidPlanner orAndropilot it could also offer GUI components to switch mode or read settings while going through the checks.
Below is my checklist for an electric plane. It might look different depending on vehicle (even for fixed wing planes). I think it would be important to make such checklists configurable. The user should be able to re-order and add/remove items.
From preparation to launch, during the mission and while landing different checklists are required. The checklists could be organized in tabs.
My checklists:
Preflight check
[  ] Check payload battery
[  ] Check payload on
[ ] Check UAV battery
[ ] Check airspeed sensor clear
[ ] Turn on transmitter
[ ] Mode manual
[ ] Power idle
[ ] check prop clear
[ ] Power up UAV
[ ] block airspeed sensor
[ ] don't move UAV until elevator flicks 3 times
[ ] Connect telemetry
[ ] Check 3D GPS fix
[ ] Check altitude
[ ] Check airspeed
[ ] Check Home Location
[ ] Check cruise speed
[ ] Set home altitude to realtive alt.
[ ] Check moving surfaces [Manual]
[ ] Check moving surfaces [Stabilize]
Mission planning
[  ] Wind direction and speed?
[  ] Auto take off? Angle ___, Altitude ___
[  ] Check default altitude ___
[  ] Check altitude graph
[  ] Check distance
[  ] Upload mission
[  ] Download mission again and check
Take off
[  ] Check prop thrust?
[  ] Takeoff flight path clear of obstacles?
[  ] Mode auto
[  ] Check elevator (auto takeoff only)
     launch against wind
Landing
[  ] Check home altitude
[  ] Check wind direction and speed
Shutdown
[  ] Power idle
[  ] Mode manual
[  ] Disconnect Telemetry
[  ] Power off
  • Link back to the original proposal which can be done in conjunction with this one
     http://diydrones.com/profiles/blogs/ask-not-what-your-hobby-can-do-...
    Intergrating it into Droidplanner, missionplanner and Andropilot would be great.
    Can the creators or the various softwares please collaborate to make one universal checklist which is identical on all software.
    Keep the uniqueness of the program but for the sake of safety and ease of use, make the checklist Tab universally the same.
  • If there's anything I can help with as far as coding or anything please let me know.  This would be amazing to get functioning with the sensors.
  • My compliments on the idea. Just a checklist is a pretty simple thing to accomplish. Making it interactive with the sensors a bit less simple but should be feasible with some teamwork here.
  • Bravo Simon!!
    Things like a pre flight checklist will help restore the FAA's confidence in the integration of civilian/business use of unmanned aerial vehicles!  With the coming of collision and avoidance software/hardware we are only a few steps away from having complete sUAS systems.  I think it's time we all take a step back and look at manned flight and why it's so safe and why the FAA has an utmost confidence in manned flight procedures.  Going through and adopting safety features that are used in manned flight and converting them to unmanned use is extremely important to the Integration of Drones.
    Again Bravo on the Idea!.
    Joshua Johnson
    Diy Drones News
  • Great idea, if it could be integrated with a simple flight log for the phones/tablets even better!
  • Admin
    Gary ,
    pls send them invitation  if possible/needed.
    Very good Idea guys, a check list for every droner.  Yep will atleast  avoid silly mistakes if not the worst ones.
    Brilliant guys, please try and join the flight standards group and lets thrash this out there. Someone will approve you as soon as you are spotted.
  • Great idea,
    I'd certainly use it myself, and if we can get something I'll be more than happy to make a wiki page for it.
    Probably be good to have separate ones for Plane and Copter (and Rover too for that matter).
    It might also be nice if it was easily adjustable where you could add or delete or even customize individual entries.
  • T3
    Here is my quick revision of your list for my purposes. I think it is also important to add some additional information about the mission and to be able to log all these data for documentation purposes.
    Mission/Flight data
    Operator ___
    UAV description ___
    Date XX.XX.XXX
    Time XX:XX
    Home location lat XX.XXXX long XX.XXXX
    Mission planning
[ ] Auto take off? Altitude ___
[ ] Check distance
    [ ] Check mission time ___
[ ] Upload mission
    Preflight check
    [ ] Environmental conditions ok for mission
    [ ] Check sensors (airspeed, ultra sonic, ...)
    [ ] Check motors and props
    [ ] Check prop clear
    [ ] Turn on GCS
    [ ] Power up UAV
    [ ] Check telemetry connection
    [ ] Check altitude
    [ ] Check airspeed
    [ ] Check if payload is connected and powered
    [ ] Check UAV orientation
    Take off
    [ ] Arm UAV
[ ] Mode auto
    Landing
    [ ] Check speed
    Shutdown
    [ ] Disarm UAV
    [ ] Power off UAV
[ ] Power off transmitter
  • Great idea for the interactive checklist. I have been useing an electronic checklist on my iPad for years. I like it and can't wait for either one on the android planning software or the MP software or both.
