Thanks to the Dev team for getting ACv2.9 to us, especially as it fixes a lot of features that have been broken for a while. This one in particular is one that I had been trying to get to work - http://diydrones.com/forum/topics/automated-parachute-drop.
The mission was to takeoff to 2m altitude, fly to WP2 @ 25m alt, drop the chute, fly to WP4 to a) stay out of the chutes way and b) not yaw towards home hopefully to capture the chute while it fell with the 808 #16v2 keychain camera attached to one 'copter foot, then descend to WP5 @ 5m and land.
Some of the flight was a little wobbly as I had adjusted a few PID settings yesterday while experimenting with something else. Below is how the mission looked. The setup was followed as per the camera control wiki page > shutter configuration - http://code.google.com/p/arducopter/wiki/AC2_Camera. A simple 5 gram servo released a rubber band holding the chute underneath the 'copter.
I had to change the nav speed to 2m/s because the waypoint was very close to the takeoff point and that was still too fast as the 'copter had reached the waypoint before the 25m altitude had been reached.
Waypoint radius was set to 1m and I had turned AUTO_VELZ_MAX to 150cm/s from 125cm/s but that also made the takeoff very/too rapid.
@Alan,
AC3.1 has a less aggressive take-off. This is available for testing through the mission planner's Beta Firmware's link on the firmware screen. you can also set the climb speed using WPNAV_SPEED_UP but this will apply to all climbs during waypoints.
Hi guys, great work graham! I noticed that i have been having the same issues regarding the aggressive takeoff. Has this been resolved? If so, is there some parameter i should change to make the take off more smooth?
Thanks in advance!
Hi Randy,
Is there any progress in the issue you created? Will we, Arduplane users be able to use do_set_servo command soon?
For a contest FFD2013 we need to release locking pin of 0.5lt water box holder during a guided flight. 3 boxes shall be dropped, so we need to activate ch5, ch6 and ch7 of APM by do_set_servo command. On Arduplane V2.71 I couldn't make this command to work, to drive a servo automatically. Maybe someone could do this.
do_digicam was never implemented for planes but do_set_servo should work. I've created an issue for it here so Tridge or I (or maybe someone else from the community) will hopefully get a chance to look at it.
Getting do_set_servo working shouldn't be hard. I think it's just a small bug somewhere.
dang guys....I've been smacking my head on this for a plane.
I can't get do_set_servo or do_digicam_control to work on a APM 2.5+
Anyone had it working yet?
JC
awesome!!!!!!! Keep up the good work! Please keep posting more videos.
Hi Peter, thanks. BTW this WAS using auto-takeoff, but I started the motors first and actually did the lift off myself before switching to Auto otherwise the takeoff is very aggressive. The takeoff altitude was set to 2m so it went to that height before heading off to the WP. In one test the WP radius was inadvertedly set to 30m which caused the chute to release about 2m from the takeoff point at 2m altitude so WP altitude definately has no priority.
Well done Graham, got there at last eh!
I went a different route. External MCU to control the parachute servo, this was to be triggered by the relay-on code (either pulsed or set to on, didn't matter). Was deciding on a port to use. was going to use A9, and alter the servo lib file to use a connected pin on th MCU. But then Xmas and other things got in the way, now things seem to have been resolved! At least with using the camera trigger command.
Randy, I can only speak for v2.81 which I tested extensively. As you say, as soon as a WP radius is reached, the next Wp is executed (current height ignored), however it will still climb after that wp. depending on the next wp height.
I explained it in a pdf file (if I can find a way to upload it). Not through code but through observation. All done on video too.
Graham, Had you used auto take off, then it would have reached specified height before heading off to first WP
Randy, Just for your information, Servo code still not tested, Relay code cannot work as is, due to relay.lib addressing an unconected pin on APM2 & 2.5. MCU. Yaw to a compass position not working, (this was with gimbal disabled) Think the yaw code is now only reached if gimbal is enabled. ROI not working...
Randy, the descent to 5m from 25m also reached 5m before WP5 was reached (about 1:12 on the video) so it got to 5m and then continued about 3-4m to WP5. I have the logs if they are of interest.
Pretty cool Graham. I was looking at trying to drop something from mine (a first aid pack) to simulate a mission. But was told this is illegal? I dunno...
