jDrones News: Upgraded jD-MiniOSD
3689447267?profile=original
jDrones News: New jD-MiniOSD with switching power regulator
(picture from test batch, production boards will be black)
We are proud to precent first set of electronics, jD-MiniOSD v1.0
Heating issues By Gone..., we made upgraded version available of OSD that has full support for MAVLink and ArduPilot electronics. This board can handle input voltages up to 42 volts so you can easily hook up your 2S - 6S LiPos without making overheating it. This switching regulator version of the OSD was originally developed by Sam Kelly from 3DRobotics
Boards are fully compatible with original MinimOSD.
OSD firmware written by Sandro and Jani.
ArduCAM OSD Config writen by Michael Oborne.
Original PCB design by 3DRobotics
Technical details:
 - Atmel 328 MCU
 - MAX7456 Video chip
 - 600 mAh Switching power supply
 - Input voltage 5v (from FTDI) and/or 6 - 42 volts (external)
 - Size: 17.8mm x 44mm
And what is the best, we made it more efficient and price is only 49.95 USD
Deliveries will start mid March. You can Pre-Order yours from jDrones store.
    It has not disapeared, we just had to temporary hide it due request from higher level. It will be back soon.
  • T3
    What happened to the product page? I see it has disappeared. I was really looking forward to it. Hopefully it's not going to be a no show.
  • T3
    Did the price change from $49.95 to $54.95?
    Thanks Jani for the reply :)  In any-case is this board open source and will you be publishing the schematic and board files if they have not been done so already?
    Alex, you cannot upgrade old board as this board have fully re-designed power supply system. So you need to change PCB designs and everything to make it work.
    Looks cool, but where are the schematics and board diagrams for the new version?  Since I already have a minimOSD I would like to see if I could "upgrade it" to hook up higher voltage lipos..
  • Congratulations on the new board, it looks promising, please let me know once the board is in stock and fully test so I will buy one, thanks for all the support.
