KamKop BL Gimbal for Sony NEXn Cameras
3689521617?profile=original
I would like to present to you a new BL Gimbal designed and build by KamKop Systems. The gimbal is available as a D.I.Y. kit and it includes all the frame parts needed to build the gimbal to fit Sony NEX cameras with SEL-16F28 or SEL-P1650 lenses. The gimbal consists of 6 machined aluminum plates, 3 GFK plates, a camera screw and couple of 3 mm screws needed to mount all the parts together. The gimbal can be adjusted on all axes and allows the mounting of the camera in the centre of gravity. Through the adjustable camera plate, you can use the NEX camera either with the Sony SEL P1650 lens or the 16mm pancake lens. The MPU sensor and HDMI / composite converter can be mounted on the plate above the camera. The gimbal is designed for RCTimer 5010 / 0.21mm / 150T or iFlight GBM4008 motors and the the AlexMos Brushless Gimbal electronics. The final product will be black anodized and available by the end of next week for less than 200€ bucks. Total weight without motors: 234 gr. Mount plate drill holes : 1. 110 x 128 mm 2. 75 x 130 mm Preview pictures are available at KamKop Systems kamkop.de But as I mentioned the final product will be anodized black!
Videos :
https://www.youtube.com/watch?v=TU3QNOn_UrY
https://www.youtube.com/watch?v=0Rfd68kK5Dk
https://www.youtube.com/watch?v=AFHM1qVQnts
