Mig-29 Red Star 2x70mm Jet PNP Jet Vector Thrust PNP Rc Airplane
Key Features
- 10 operable channels (ailerons, elevator, throttle, rudder, retract, thrust vectoring, airbrake flaps, cockpit ejection, brake parachute ejection, smoke actuate)
- Nightflight LED lights
- Dual 360 thrust vectoring nozzles
- Capable of alpha maneuvers
- Cockpit ejection
- Controllable airbrake flaps
- With color smoke function
- Durable and high scale screw retract
- Drag parachute
- Can do all the 3D actions like real plane
- With twin 70mm EDF
Technical Specifications
- Wingspan: 1142mm
- Length: 1514mm
- EDF diametre: 2x70mm
- Flying weight: 2400g
- Thrust: more than 2500g
- Hobbywing 2 x60A ESC
- 14xDigital metal 17g servo
- 3pcs Screw servo
- 2x2100KV Brushless motor
- EPS foam material
Includes
- Mig-29 Fulcrum 2x70mm Jet Vector Thrust PNP Red star
- English manual
Requires
- Minimum 7 Channel Radio
- 7 Channel Receiver
- 6 Cels 22.2V 4000 mAh 35c Lipo Battery
- Lipo Battery Charger
Wingspan (mm): | 1142mm / 45in |
Length (mm): | 1514mm / 60in |
Flying weight (gr) | 2400g / 85oz |
CG (Center of Gravity) | Check manual |
Servos | 14x 17 gr metal gears digital |
EDF Thrust | 2x 1250gr |
Direction of Rotation (EDF Rotor) | Classic Counter Clock Wize (CCW) |
EDF Diameter Class (mm): | 2 x 70 |
Turbine shroud | Synthetic |
EDF Rotor | Synthetic |
Power System | 2x 2100kV Outrunner Brushless |
Motor Type: | Out-Runner |
Electronic Speed Control | 2x 60A Hobbywing - 5A BEC |
Battery Cells: | 6s - 22.2v |
Battery Capacity (mAh) | 4.000 mAh |
Connection: | PK 5.5mm male/female (Bullet Connector) |
Surfaces | Ailerons, Elevator, Flaps, Vector thrust, Slats, Parachute system |
Landing Gear | Plastic main and nose gears struts, Retractable suspended gear, Steering gear |
Lights | Navigation lights |
Material | EPS Foam |
Build time | 3 hours |
Radio requise | minimum 7 channels - maximum 10 channels |
Recommended pilot skill level | Intermediate, Advanced, Expert |
