My first Blog post on DIY Drones!
So this is my first post and i thought that i would share my FPV video with you guys!
A little bit of information:
Video: 1,2Ghz 800mw and 8 dBi patch antenna.
Radio: Futaba 12FG with 1W WiFi booster and 12 dBi patch antenna
Airplane: My own design and built "Dr.Marten" plane.
OSD: Eagletree
Battery: 1x4000 mah
3689431370?profile=original
    Same limit here in Canada.
  • I don't want to be a killjoy, but in the UK we are limited to 400ft altitude, I assume you have similar laws. Flying FPV at your altitude is Dangerous and irresponsible. This sort of action will get FPV banned for all of us.
  • @GrzegorzSz - around 2000 m at most if i remember right.
  • Thanks everybody!
    @Stefan - My goals with the design of the plane was to have a plane that is light weight and with a big surface area to get the maximum amount of flying time. The airplane empty weighs around 350-400g and with all the electronics it is about 1600g. The span of the wing is around 1,5 m and as you can see on the picture it is really wide. I also wanted it to be as stable as possible so that i could fly through the clouds without the plane rolling over and ending up upside down. So i got inspired by the free flight models and copied some of there characteristics.
    @Peter - Here is where i found out about the booster
     http://diydrones.com/profiles/blogs/how-to-boost-your-24ghz
    The only thing you need is the right connector for the U.FL cable in the module and make sure that the module itself is not to strong. I think my Futaba TM-14 module puts out 70mw ore something like that. If those things are ok then it should work!
  • What altitude are you flying on?
  • Can you tell me more about this 1w wifi booster, would it work with the t10chg 2.4g. Its getting impossible to find futaba radios with modules that I can replace with the FRSKY module.
    Oh and by the way love the vid, especially in full screen.
    Regards Pete
    Beautiful video!
    Do you have more info on the plane? I really like it.
  • Really nice!
