3689598322?profile=original3689598300?profile=originalWe have finished new board NEO-M8N + Compass
NEO-M8N breakout board features:
  • 72-channel u-blox M8 engine GPS/QZSS L1 C/A, GLONASS L10F, BeiDou B1 SBAS L1 C/A: WAAS, EGNOS, MSAS Galileo-ready E1B/C (NEO-M8N)
  • SuperSense Indoor GPS, -167dBm
  • On-board Ultra low noise 3.3V voltage regulator and RF filter for noise blocking
  • USB, I2C (SDA,SCL) and Uart (Tx,Rx)
  • Dual band GPS and Glonass antenna
  • u-center GPS Evaluation Software
  • Extensive visualization and evaluation features
  • Supports AssistNow Online and AssistNow Offline A-GPS services
  • 1 TTL UART port, 1 I2C port,1 USB port
  • Time pulse LED
  • Flash memory for firmware upgrade and settings inside in the module (can save setings without battery)
  • Battery for HOT module start
  • Build-in HMC5883L Compass
  • Dimensions: 50x50 mm hole distance 45x45mm
  • Weight 24 gram
  • Fully assembled and ready to use
  • Hello!
    I think price the same as LEA-6T boards.
  • CSGShop,
    Do you plan to release any LEA-M8F based devices? If so, what price would it approximately be? (i.e. less than your LEA-6T devices?) What are the benefits over LEA-6T?
    Thanks,
    Dan
  • 3.3v But I have checked Ublox I/O pin it's 5V tolerant.
  • What is the logic level of the I2C and UART? Can't find this info anywhere
  • you are fast man....great...I wish all the shops over internet can react that fast as u did....
  • Now also avail HMC5983 version
  • @Thomas, thk !!
  • thanks thomas.
    this gps seem to be very accurate
  • @ Para : Pictures of this will be interesting.
    But then I removed the NEO module and antenna and replaced a NEO-6 on a GPS that has external SAW and LNA
    And I am surprized that a SAW Filter coming with the NEO6 (1575 MHz center) does´nt block (damp) GLONASS signals at 1602-1615 Mhz ? Usually the bandwidth (e.g. Murata SAW) for GPS SAW is around 2 MHz
    Same goes for the antenna: First thing I thought, when I saw the tiny active patch of the evaluation board, that I want to replace it with a biggger patch. But I did not find a Dual band antenna.
    So I am surprized.
