Over the past couple of weeks I have been busy reworking my original APM Mission Planner. Together with my partner/designer Samantha Nelson we have focused on improving the APM Planner’s interface, ideally resulting in a more intuitive user experience.
Below are a couple screenshots of the new APM Planner!
APM Planner Version 1.0.0 can be downloaded here -
chris:
ok i will tray microsoft.net framework is 3.5, i hope it's gonna work. :-)
regard.
Adi: are you using the latest Mission Planner 1.0.82 on a machine with dot.net framework 3.5 installed? That's automatic on Win7 but on XP you've got to install it yourself. (This is all in the manual, BTW)
Hello.
when i tray to running this one, i got this error report:
EventType : clr20r3 P1 : ardupilotmegaplanner.exe P2 : 1.0.0.0
P3 : 4e95968e P4 : mscorlib P5 : 2.0.0.0 P6 : 4333ab80 P7 : bd0
P8 : 59 P9 : system.formatexception
how i can fix it??.
many thanks for help :))
regard.
Hi Michael-
The planner gets better every day! We are so close to actual missions - any idea when 2.0.39 will be downloadable in planner?
Hi Dario,
What you are asking i cant change.
at the moment the current frame rate is based entirely upon your cpu speed. because im drawing over the top of a image, this consumes alot more cpu than using a overlay. Also the image scaling should fit any res screen into that box, so i dont know why yours is outside of that. it would be a overscan issue with your capture device. My suggestion would be to use another program AMCAP ? to display your fpv, and dont run the planner full screen. as this will give you the best posible video performance.
Michael
Hi Michael,
Congratulations for your amazing job! It´s awesome!
The AP Mega Planner looks impresive, it´s more than a professional gcs, it´s all in one!
I use the Remzibi OSD (maybe you remember my issue about the "enable hud overlay" option), and I use PAL format. When I activate my video Input in AP Planner, some data don´t appear properly because the Planner doesn´t adecuate the video resolution. Could that be solved?
Other thoughts,... It´s possible to increment the video frame rate in the Planner? I think now is about 15 fps...Could be 25 fps?
And the last, Can I set up the Planner to open my video input and disable the hud overlay from start (when I open the Planner)?
I don´t open a new issue in the repository because I think those comments are not a issues, just an enhancements.
Thanks for your time and for your effort. (Sorry about my English mistakes).
Regards from Spain,
Dario.
It is not a big deal, but I think the simulator tab needs to be reorganized. It is better to design a few zones to separate the buttons, settings and status.
I have noticed an occasional bug happening for past few weeks. When I get a new version I do first time setup. The radio numbers come out fine, but the unit yaws badly to the right at takeoff. I then just run radio setup in cli and I am good to go. This has happened several times in different versions (again today for 2.0.38, planner 1.0.47), I wonder if some of the complaints Jason gets about yaw really relate to this. Anyway, radio setup in cli fixed it every time.
Thanks, Michael - this thing gets cooler everyday!
thx
