New! APM Planner 1.0
3689411504?profile=original
Over the past couple of weeks I have been busy reworking my original APM Mission Planner. Together with my partner/designer Samantha Nelson we have focused on improving the APM Planner’s interface, ideally resulting in a more intuitive user experience.
Below are a couple screenshots of the new APM Planner!
3689411466?profile=original
3689411394?profile=original
APM Planner Version 1.0.0 can be downloaded here -
https://code.google.com/p/ardupilot-mega/downloads/list
    please update, the latest MP is 1.2.95
  • Hi, I am using the Mission Planner 1.2.47, I am able to locate the geographical co-ordinates and send it to the MAV. But I am not able to tune the values of P I D, where the particular field is inactive and I cannot vary those values and send it to the MAV. What is the way to make it active, so that I can vary the P I and D parameters. Kindly reply. My email is
  • Yes,it work fine now. I mean that if I can use it freely?
    so long as it talks valid mavlink, and can process paramater requests it should work fine.
  • Hello! Michael:
    I used MAVLINK for my fix-wing FPV OSD, can I use Mission Planner even if my OSD isn't the FREE or GNU software? It use the Flight Data&Planner.
  • Just wanted to say thanks, Michael, for fixing APM planner so that it works under Mono! I'm using it in Ubuntu without a hitch! Amazing!!
  • hy..
    can i convert the tunning data into notepad??.
    thanks
    regard
  • Martin, Jim
    We have some experimental code where you trigger the camera via a mavlink message from the GCS mission planner, or via a mission command.
    It supports both servo, relay, or a camera electronic trigger signal.
    But the code is still experimental, but stay tunned, it will come.
  • I think it depends on what type of shooter you use.
    I have two different cameras and I use DO SET SERVO with one and DO SET RELAY with the other
  • I would like to know what is the command to shoot a camera on a waypoint?
