www.engadget.com/media/2009/05/invensensememsgyromotion6-axis.jpg"/>
Press Release"The world's first 6-axis MEMS-based motion processing solution delivering the smallest, most robust inertial measurement unit (IMU) for CE applications. This solution includes two 4x5x1.2 mm packages for the gyroscopes and one 3x3x0.9 mm package for the accelerometer, providing a small 7x7mm equivalent footprint with 10,000 g-shock rating"Looks great! It says world's first, but i swear there was already an Analog Devices onearound , but very pricey... Anyway, I cant wait to see this in a RC plane. Good to see prices falling.I wonder if this was what was used in the IMUDot we saw earlier?You need to be a member of diydrones to add comments!
also let me advice u Viagra Online
is amazing .
From the block diagram the ADC is included into the accelero wich seems like a bit of an odd solution to me, why not make the gyros digital already?
That's good news. Many thanks for the info!
Hi Peter,
Yes, that is the intent of the ISZ family of gyros. This will sense the
rotation of the application around the normal axis to the plane of the PCB
in which the ISZ is mounted. Mounting an ISZ and IDG on the same PCB will
allow for 3 axis of angular rate sensing. No daughter card mounded
perpendicularly will be needed with ISZ.
Please let me know if you have any other questions.
Thank You,
Benjamin Kokes
Field Applications Engineer.
