New Micro FPV Kopter
3689422851?profile=original
The New FPV  APM  Kopter
3689422928?profile=original
In the foreground, the bumblebee
in the background the  Kamkop  with the GoPro 3D system
3689422945?profile=original
The new FPV Kopter
made vor 10" Props
to use GoPro or a smal FPV camera
3689422884?profile=original
NTM Prop Drive Series 28-30A 750kv / 140w
Motors:
 ESC:
TURNIGY Plush 30amp Speed Controller
Accu:
2200mA
3689422963?profile=original
3689423012?profile=original
3689422901?profile=original
now I'm still working to find the correct PID parameters
 for a stable and no wobbling flight i have to set the P parameter unter 1
than i have not enough sensitivity on my RC
maybe someone has experience with such a small Kopter with relatively large engines!
or someone could rewrite the code for me ?
Peter
  • the bumblebee is self-made
    I follow the system no longer
    (the prototypes and molds are for sale)
    it a video on
    https://www.youtube.com/watch?v=AgJEmOJRtr0&feature=related
    On my FPV Mini Quad i have now
    P on 2
    I  on 0
    It flies very well
    but
    the sensitivity of my remote control is to low
    how can I change it ?
    test the acro mode?
    Peter
    Yes, The D term has been renamed P-Rate
  • Is your bumblebee a kit or a DIY?  I'd love to see some more pics if it's DIY,
  • @Ryan with D do you mean P-rate?
    As far as I know there is no D term... :)
    @Peter
    I have been playing with the P-rate and raising it (or lowering it) does make a difference on how the quad reacts even on stabilize mode.
  • Hi,
    2mm GFK
    ca. 800g
    Peter
  • hello
    What material is this made out off?
    How heavy is this quad when it is fully loaded?
    steven
  • hello Guntars,
    the Spacers are from Conrad-Elektronic in Germany !
    Peter
  • Where do you buy spacers (black cylinders between arms)?
  • This huge overlapping is like having unbalanced propellers.
    A propeller increases airflow velocity/decreases pressure and the below propeller has to cope with 2 different airflows on each blades.
    Ok, it is... design exploration !
  • Thanks !
    i will try the D Parameter !
    the Quad is OK ! no Problems with the overlapping !
    i fly it also good with the HK System
