Check it out: an all-in-one telemetry kit for ArduPilotMega, all set up and ready to go! No more fussing around with Xbee configuration. $165 for the total, which includes the custom configuration.
In this kit you will find everything you need to add telemetry features to your aircraft set up. The Xbee modules come paired up and ready to use! Included with this kit:- 1x XtreamBee Board (The one manufactured by DIYDrones!), including the two female connectors and right angle connectors.
- 1x XBee-PRO 900 extended range module w/ RPSMA connector and duck antenna
- 1x XBee-PRO 900 extended range module w/ wire antenna
- 1x Xbee Explorer Dongle (USB adapter for the Xbee module!)
What is the best antenna to use on the plane side xBee 900? I have the little wire now but would like to improve it. I have some SMA connectors I can solder on or is there another option? I'm losing connection at about 1km which kills the antenna tracking. I will put a Yagi on the antenna tracker xbee but I would like to improve the plane side xbee and also the computer running the MP. That just has a whip antenna that came with it.
On the telemetry page of store I don't see the full xbee kit listed at all???
only the XtreamBee Board (No XBee included) is listed
Al
Woo! back in stock
Hi
THe telemetry kit is no longer on DIY store. Is this temporary or is it no longer sold there?
thanks
Al
any plans to re-stock it ?
