After a few months of hard work, SplineNav 0.3 is now ready to fly! This SplineNav release started with the goal of simply reducing the yaw jitter issues of SplineNav 0.2, but in the end it turned into a major rewrite of the code.
New Features:
  • Smoother Yaw: Updates x and y spline derivative calculations faster, in a separate loop, for a more precise yaw control. Uses a fast approximation of the atan2 function to compute the yaw angle from the spline derivative.
  • Features yaw rate smoothing for much smoother video, avoiding the small yaw "jerk" at each waypoint.
  • Allows manual override of yaw control, then takes back auto control of yaw if the pilot centers the stick when yaw is directed approximately in the direction of the spline curve.
  • Now enters SplineNav mode smoothly, without an initial jerk.
  • Uses it's own flight mode, so unlike SplineNav 0.2 it doesn't override your Circle mode. To use SplineNav 0.3, set one of your FLTMODE parameters to 14 in the Full Parameter List.
SplineNav Waypoints
We collected the waypoints for this video while flying FPV, and flipping the channel 8 switch at each point to record. Then we loaded the waypoints into Mission Planner, and made some small adjustments:
Waypoints recorded during FPV flight and adjusted in Mission Planner
The GPS track indicates it hit all the waypoints quite precisely, on each lap for a total of 3 laps (72 waypoints in total):
GPS track from dataflash log shows SplineNav hitting each waypoint precisely over 3 complete laps
The waypoints had a range of altitudes set, from 7 to 35 meters. Here is the flight profile from the autopilot logs, imported into Google Earth:
GPS flight profile from dataflash logs after 3 complete laps
Hardware Used:
Airframe: 3D Robotics Quad, with some modifications.
Autopilot
: 3DR APM 2.6, with external compass/GPS module
Motors
: T-Motor MT2216 KV800
Props
: APC 11x4.7
Gimbal
: WIND-1 two-axis brushless
Camera
: GoPro Hero 3 Silver
Telemetry
: 3DR 433 MHz
R/C
: FlySky TH9X(ER9X FW) + 2.4GHz FrSky DJT module + V8R7-II rx
FPV
: ImmersionRC 5.8GHz 600mA + FatShark Predator + SecurityCamera2000 CMQ1993X
Also: These mods for longer range FPV.
SplineNav 0.3 Firmware Installation:
  1. First make sure your quad copter is flying well with ArduCopter version 3.0.1, since SplineNav 0.3 is based on this firmware version.
  2. Go to https://github.com/mavbot/SplineNav, and click the "Download ZIP" link.
  3. In the special Ardupilot version of Arduino, go to File -> Preferences and set your sketch directory to the path of the "SplineNav-SplineNav-0.3" directory from the extracted zip archive.
  4. Restart Arduino, then choose File -> Sketchbook -> ArduCopter from the menu.
  5. From the ArduPilot menu, make sure your HAL Board is set correctly.
  6. Connect your copter's APM via USB, and from Arduino's Tools menu make sure the serial port is set correctly.
  7. Click the Upload arrow button and wait for the code to compile and upload to your APM.
  8. Set one of your FLTMODE parameters to 14 in Mission Planner's Full Parameter List, set your waypoints (either with Mission Planner or with the channel 7 or 8 switch), then go fly!
Note: If you have any special requirements, such as a frame or orientation other than quad X, remember to make those adjustments in the code before compiling. Or if you'd rather not compile yourself, please contact us to get a hex file you can upload directly via Mission Planner.
Parameters
Here are the speed and acceleration parameters we used for this video (set in Mission Planner):
WPNAV_SPEED: 1350 cm/s
This should make SplineNav go about 49 km/h on straight segments.
WPNAV_SPEED_UP: 1000 cm/s
WPNAV_SPEED_DN: 650 cm/s
WPNAV_LOIT_SPEED: 1500 cm/s
Should be set higher than WPNAV_SPEED.
WPNAV_ACCEL: 180 cm/s/s
Nice low value for a smooth steady start.
Also, the following parameters are #defines in the splinenav.h source code, and can be changed at compile time:
SPLINE_TENSION: 1.6
Higher tension splines curve more tightly at waypoints, but straighter in between waypoints. A tension value of 2 makes it a Catmull-Rom spline. We found that slightly lower tensions tend to give nice loose curves for smooth aerial video.
SPLINE_CURVE_ACCEL_MULTIPLE: 2.0
This allows for twice the max curve acceleration as set in the WPNAV_ACCEL parameter. Added this parameter to allow for smooth slow starts without making tight curves overly sluggish.
SPLINE_JERK: 200.0 cm/s/s/s
Jerk is the maximum rate that SplineNav increases or decreases acceleration as it flies the curve.
SPLINE_LOOP: true
This makes SplineNav loop the waypoints forever until you exit out into another mode.
  • and by the way, amazing work.. and of course I am wondering .. will it work with a 3DR Y6?
         hzl
  • hmm and this DOES bring up a rather obvious question.. is there ANY way to instrument the processor load on the AVR cpu , ie how do we know when its time to move to faster processors for ardupilot like what is already been done with pixhawk? And of course the above implied question is how do x8,y6 affect processor load vs hex and octo configs vs a quad or a tri configs.(guess its time for me to start coming through the ardupilot source tree... :)
              hzl
  • Thanks David.  This is great work.  Can't wait to try it out.  I'm running a hex but was considering a x8 or y6 in the future and was not sure how it loaded down the processor.
  • Thanks Gary! Still working on getting the jitters down, hopefully that can be improved in order to get really smooth video from it.
    Skippy, it wouldn't hurt to try it on the octo, you'd just need to define FRAME_CONFIG to the OCTA_FRAME configuration in the APM_Config.h source file, instead of the default quad config. Then compile and upload, and go test fly it. Switch into SplineNav mode, and switch back out if there are any issues due to insufficient processor time. There shouldn't be any danger of it falling out of the sky, because the scheduler will simply degrade telemetry and other non-essential functions first.
  • Nice work, smoother for sure. Love the music and how well it goes with the tempo and pace of the film. When you look down on the path, when you least expect it, your new camera will be there.
    This is awesome. I'm glad you keep improving it!
    Beautiful
  • Amazing work!  Hope this makes its way into a regular release in the future.  Would this code work on a hex or octo with the 2.5/2.6 controller?  I know those guys are pushing the envelope on processing with octo's already but it seems the devs have managed to streamline some processes and get the loop speed back up.  Keep up the good work.
  • Chistriaan, SplineNav is a navigation controller that follows curved paths consisting of cubic equation segments connecting waypoints in 3D space, instead of straight line segments. At each waypoint, derivatives of the connecting segments are matched up, so the curve is smooth.
    Cronselaar, I first found my waypoints with FPV, using the channel 8 switch to record them, then adjusted them how I wanted in Mission Planner, then loaded them back onto the APM.
  • @Christiaan.. Just seems like a protocol to follow "splines" between waypoints and integrating yaw across the length of the spline instead of only changing yaw direction once a waypoint has been achieved. Nice and smooth yaw changes as you would from flying a plane...
