New Tricopter Delrin Kit available late August
The new Pro Tricopter Delrin Kit from fpvmanuals. Motor mounting options: Up or Down. Super precise, slop free Yaw mechanism with ball bearings and airplane grade aluminum axle. Foldable boom design. All laser cut parts including Delrin frame and motor mounts, Bamboo camera mount, and acrylic feet and flight controller cover.  Over 142 pieces of hardware included in the kit. All up weight, fully built, only 630g (without battery). Kit does not come with booms/arms: your choice on material and length to suite your needs. Learn more about the kit at:
http://www.fpvmanuals.com/tricopter
Kit available late August / early September for $89.99
(put yourself on the pre-order list to get it for $75 when it becomes available)
  • any chance on making your mounts dual's for those who want the extra lift of a Y6?
  • What else is made from Delrin?  Guitar picks! Thin Delrin that can be hit against metal strings for hours on end, with force and without breaking makes for a good tricopter frame material.
  • Hooks: Only the flight controller cover and feet are acrylic. The frame and motor-mounts are made of Delrin -- a super strong plastic that, in my opinion, performs better than fiberglass. Fiberglass is harder and will break on hard impact. Delrin will give instead of breaking on a hard crash. Delrin is, in my opinion, also a better choice for FPV tricopters over carbon-fiber as it does not interfere with the video signal, which carbon-fiber can.
    Plexy Glass: Cheap yes.. Any good? No...
    BTW: looks good.
