PARACHUTE anyone ?
3689396321?profile=originalMaybe someone has encountered a small scale parachute ?
I'd like to add a safety parachute to the Arducopter !! help me decide....
As part of the project is to use an expensive DSLR on the copter,
My GF said i must have some kind of emergency parachute... after joking at it, i thought deeper -
I'd rather feel much safer having a parachute as backup to all electronics (even though i plan on 6 or 8 motors)
Just imagine an emergency button that will immediately turn off all motors and shoot a parachute.
questions:
as parachute takes some time to open (=some free fall height), the benefits are sure and obvious for a 100m fall.
but if i'm around 5m above ground, (which can still be nasty to the DSLR) - would i have enough "falling time" to open the parachute and having enough braking force ?
think i better make one by myself ? is it rather simple as cutting and connecting wires to a cloth,
or it is more complex design that i could hardly achieve and i better get a ready one ?
i came across this as the only parachute i could find:
http://cgi.ebay.com/NEW-40-SPEED-RUNNING-POWER-CHUTE-training-parachute-/220760637799?pt=LH_DefaultDomain_0&hash=item33665c0167
It looks sturdy and well balanced & stuff... it's totally affordable !
they say the 40" version has 7KG resistance. i'm safe on this side, i dont want a much bigger one.
how about the opening technique ?
i could stuff it in a small plastic tube attached to the top of the dome, using a small solenoid or servo to kick it out...
how do i ensure it opens reliably ? i guess it depends on the folding inside the storage tube...
  • @Zak - slight off-topic, but they do have an airframe is thats something you've been looking for
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
    I am re-purposing a large 50" Golf type umbrella $2 from Bargain  Mart. It has 8 panels, 3 red, 2 white and 3 blue, weighs 74 grams bare . It's now off the frame waiting for sewing on 8 lines, I was planning on using mason's nylon line, but it might be to much, maybe 30# sailplane tow line.  I will use a spring to eject chute upward, chute will have a coiled 1 mm fiberglass rod sewed in that will spring open right after ejection. I don't know how /when it will be triggered yet.
  • or fatal to a DSLR ;)
  • but do we realy need parachutes ;)
    YES.
  • @Martin-
    right, but then i have to add 4 small relays (or 2 double pole) to switch the signal off the APM.
    i've seen a warning somewhere to NEVER disconnect an ESC from the APM while running. (that could damage APM)
    I really prefer the electronics disconnecting option...
    i guess i will have to experiment what happens to the ESC in that case...
  • I think of getting this one.
    http://cgi.ebay.com/48-Red-Model-Rocket-Parachute-Quality-Rip-Stop-...
    the description says 'slow descend' for 1.5kg and moderate speed descend with ~2kg...
    my copter will be more than 2kg, so i think there's no chance i'll try some smaller than 48"....
    on the same hand, i hope 48" will be enough...
    Springs work as well
    http://vimeo.com/8904576
  • for sending 0% throttle i have to use the copter code, and at the moment of truth i rely on the electronics.
    if the quad fails because of the electronics, i cant use the software to turn off the motors...
    i must have an aggressive and simple way to switch to emergency state, like disconnecting the motors or the APM
  • Here i found a successful one, @ 0:40
    https://www.youtube.com/watch?v=NbQryfscr-U
  • exactly,
    this video is exactly the opposite of any common sense design...
    now to some experienced user question -
    If i disconnect the power of the APM/IMU/TX all together off the BEC, in the middle of a flight while motors running,
    but the ESC's are still connected to the battery - what will happen ?
    (in other words what happen when you unplug an ESC signal cable while running)
    hopefully this will stop the motors, that way i can put a relay to disconnect the 5v electronics, rather than having to use a very high amperage relay to disconnect ESC's off the LIPO....
