Here it is! Finally, the PixHawk Fire Cape (PXF) is ready for a wider audience and we've launched a crowdfunding campaign so that everyone can get theirs. We've been iterating through different generations over the last year and with the help of many, we are finally proud to announce the PXF starting at $100.
This board was born out Philip's hands and pushed by members of this community so it's just reasonable to try making it as affordable and accesible as possible. Some technical details:
Sensors
- MPU6000: 3-axis gyroscope, 3-axis accelerometer and temperature sensor.
- MPU9250: 3-axis gyroscope, 3-axis accelerometer, 3-axis magnetometer and temperature sensor
- LSM9DS0: 3-axis gyroscope, 3-axis accelerometer, 3-axis magnetometer and temperature sensor.
- MS5611-01BA03: Barometer that includes pressure and temperature sensors.
Connectors
- 3x LED indicators (Green, Amber and Blue)
- 2x serial UART ports (ttyO0 is not active)
- 1x CAN connector and transceiver
- 3x I2C ports
- 1x Buzzer
- 1x Safety switch
- 9x PWM output channels
- 1 PPM/S.Bus in
- 1x Spektrum
- 1x Power brick connector
- 1x Battery backup (1 LiPo cell)
- 1x ADC
- 2x GPIOs exposed (IO)
- 1x analogic pressure sensor (AIR)
Mechanical characteristics
- Size: 88.6 x 54.73 x 20.69 mm
- Layers: 6
- PCB Thickness: 1.62 mm
- Weight: 31 grams
Support the crowdfunding campaign of the PXF here.
it looks a very promising item. do you think it can integrate a builtin OSD?
Early-birds have just been sold-out but for those in the community still interested, we've opened a BBB+PXF perk that allows you to get a Linux autopilot with multiple IMUs for 150 €.
You can get yours here.
Contributions by country so far:
Thanks everyone for the support!
@ Rob the word drone came from the 1930s Tiger Moth autonomous adaptation which was called the Queen Bee.
Victor: Name/pic look much better! Backed and tweeted...
@Rob: If memory serves, this was originally designed by Philip Rowse for a fire-spotting drone application in Australia. The application passed, but the name stuck!
Someone asking on reddit: Why is it so expensive? I don't think a few sensors and some connectors are that expensive...
Ant colonies have drones, just as bee hives do.
Doug, I figure the word "drone" applies to ground based robots just as well as it does to aerial robots. It's only in colloquial usage that it is defined to mean flying robots.
1
2
3
4
5
of 5 Next
