Disclaimer: I don't know what I am doing. This seems a bit more complicated than other solutions I have found (since I had to use the Sub Trim) but it works with what is the latest T8J firmware (I think I have the latest but cannot confirm since I see no way of knowing the version # or upgrading the firmware).
These are my settings. I had to use the Sub Trim to move the PWM output of the C switch in the middle position so I would have access to the third mode with D off and fourth with C on (up).
I would welcome feedback if you think there is a simpler way to do this. My screens just didn't match the example that the Wiki points to (http://diydrones.com/profiles/blogs/acmapm-futaba-t8fg-super-mode) or other posts here regarding the T8J.
I assume this is going to become a fairly common radio since it has an SBus receiver and is not too expensive) through the new Taranis looks great.
Hey all,
I have a T8J as well and here is the configuration I wish to achieve.
I would like to combine SWF and SWE to do the following;
SWF - down SWE - down Flight mode is Loiter
SWF - down SWE - middle Flight mode is Alt Hold
SWF - down SWE - up Flight mode is Stabilize/manual mode
SWF - up SWE - down Flight mode is Autonomous
SWF - up SWE - middle Flight mode is Circle
SWF - up SWE - up Flight mode is RTL, return to launch
Attached is a pic from the configuration software(Mission Planner).
ID: 2012021" class="thumbnail" alt="Click image for larger version.
ID: 2012021" src="http://www.rcuniverse.com/forum/attachment.php?a...
My other objective is the ability to switch out(in case of emergency) from Autonomous mode to Loiter with switching SWF from the up position to the down position and take over manual control.
I understand this can be accomplished and needs the steps to setup the above configuration.
TIA,
Tim
What am I missing though?
@FrenchGuy I ordered my Pixhawk and waiting for it to arrive in the next two days. I'll definitely try your config on my Futaba 14SG and reply back.
Thanks.
And the graph looks different:
`![2014-02-27%2007.45.03.jpg?width=500](https://dl.dropbox.com/s/cwv92tg9w5x3lf1/2014-02-27%2007.45.03.jpg?width=500)
@Hein, I followed your instructions but I end up with the Mid-C Low-D position to be one state too low (at 1514):
Please find below some settings that worked for me.
@Chris, I am not sure that's the best way to do it. I would like the community to validate before it's made gospel.
Thanks for this. I'll update the wiki to point to it.
