MR60
Pixhawk suspended FPV quadcopter - Mark II - build log
3689571797?profile=original
As a follow up of my first tentative to build a suspended FPV quad , here come design Mark II. It uses mostly wood instead of aluminium. The whole blog consists of pictures with integrated comments on them. Enjoy...
3689571736?profile=original3689571591?profile=original3689571812?profile=original3689571912?profile=original3689571860?profile=original3689571926?profile=original3689571825?profile=original3689571850?profile=original3689571973?profile=original3689571873?profile=original3689571947?profile=original3689571998?profile=original3689571887?profile=original3689572010?profile=original3689572063?profile=original3689572031?profile=original3689572084?profile=original3689572109?profile=original3689572202?profile=original3689572130?profile=original3689572223?profile=original3689571797?profile=original3689572252?profile=original3689572246?profile=original3689572156?profile=original3689572273?profile=original3689572309?profile=original3689572178?profile=original3689572286?profile=original3689572187?profile=original3689572330?profile=original3689572359?profile=original3689572351?profile=originalEnd of part1... Next will come the assembly of the propellers protection system and of course the maiden flight. Stay tuned...
  • MR60
    Hi Doug, my god you were reading my mind about the lamp rings! This is preceisely what I was going to do. I will gain therefore 30% of the weight...but shhhh still in progress, wait for the next batch of pictures & test flights.
  • Well done! It is nice to see a different perspective on a quadrotor.
    You are, of course, obligated to share performance information with us. ;)
    The 'over/under' propellor debate will probably need a bench test for good data. You certainly receive points for integrating it into this build. If weight needs to be shed (it *always* need to be shed) you could clip out the inboard section of your lamp rings.
    I hope you can capture some video to share with us.
    Build on!
    -=Doug
  • MR60
    @Steve, total weight is 1.5kg without battery. By the way , for clarity, the main battery sits on the bottom side of the plate. A second smaller battery for fpv can also be installed on top of the plate just next the fpv pod.
    Dimensions of the quad : 40 cm from motor to motor.
  • that's awesome design! thanks for sharing.
  • MR60
    @ Stephen, yes as soon as it will be prepared for flight I will compare above and under. However apart from pure efficiency, putting mptprs under the arms reduces the air flow impact on the arms and thus vibrations.
  • T3
    What a beautiful build!  Very clean.  If you have a chance later on, could you please test something for us as a favor?  Some people maintain that mounting the motors under the arm hurts your efficiency.  Could you test the efficiency for props above and below the arms?
