Pixhawk vibration dampener.
3689647297?profile=original
I want to show you my Pixhawk vibration dampener that im currently using.
I used the 65g Dampeners from Hobbyking. The bottom plate is 1,5mm gfk and the dampened Controller plate is 0,8mm carbon that i had laying around.
The holes in the bottom plate are slightly offset to the side to keep some tension on the Controller.
So far it works really well.
3689647602?profile=originalif anyone´s interested i can upload the dxf files of the two plates.
and if anyone is curious about the home of this pixhawk here are two pictures. :)
3689647521?profile=original3689647563?profile=original
  • today i updated to AC3.2 and did a short testflight in front of my house.
    here are the Vibration logs:
    3701988259?profile=original
    and here are the dxf files and the SolidWorks model:
    https://www.dropbox.com/sh/n643zituayagtwm/AABtB59-fmoPnMXaoVOed7rt...
    Make sure to use a ziptie on each dampener, otherwise the controller will start to shake.
    Shared Diy-Drones
    Shared with Dropbox
  • nice, please share your vibration testing and your dxf file please. many thanks
  • Nice. Really interested in dxf file. Pl share, thanks.
  • Also it would be great to see the logs.
  • Really interested in the dxf file. Possible to share? Thanks
  • Looking nice and working perfect if we put the FC on the top plate. I use 2 layers of 3M double side foam tape on my QAV500 and TBS Disco (both under top plate). Vibration level bettween -8 and -12 when hovering.
  • Looking good, I'm migrating to Pixhawk from APM this week so looking at ready made solutions out there for Pixhawk
  • Very nice. Do you have the logs to show the vibrations?
