Precise indoor positioning with ultrawideband
3689656906?profile=originalRight now, for precise indoor positioning you typically need an expensive optical motion capture rig like a Vicon. This Kickstarter project promises to do the same thing with ultrawideband wireless for much less ($500). It's already made its $30,000 goal and has four more days to run.
Pozyx is the first affordable and easy-to-use hardware solution that provides accurate indoor (and outdoor) positioning and motion information for Arduino. In order to achieve a positioning accuracy of a few centimeters, the pozyx system relies on a novel wireless radio technology called ultra-wideband (UWB). The accuracy achieved with this ultra-wideband technology is several times better than traditional positioning systems based on WiFi, bluetooth, RFID or GPS signals. Furthermore, the signals can penetrate walls and make it suitable for indoor environments.
Pozyx is many times more accurate than today's positioning technologies.Pozyx is many times more accurate than today's positioning technologies.
Results from a live test of the Pozyx system. The blue line accurately represents the trajectory of the person walking in the room. The cone indicates the orientation of that personResults from a live test of the Pozyx system. The blue line accurately represents the trajectory of the person walking in the room. The cone indicates the orientation of that person
 Key points
Pozyx is more than just positioning!Pozyx is more than just positioning!
What to do with it?
The high positioning accuracy enables a lot of applications that weren’t possible before. For example, you can program a drone or robot to navigate through a building without bumping into things. But that’s just the beginning...
Possible applications for accurate positioning with PozyxPossible applications for accurate positioning with Pozyx
We firmly believe that for indoor positioning to become great, we have to share the technology and make it easy to work with such that creative minds can come up with the next killer positioning application!
Depending on your skill level, you can use the system in several ways:
  • Beginner: Plug the Pozyx tag into your arduino and get started right away. Obtaining your position and orientation is done with a few lines of code using our Arduino library.
  • Intermediate: Use the Pozyx system as any other sensor. Connect with it through I2C. Perfect for a connection with a raspberry pie or some other platform.
  • Expert: Program the microcontroller of the tags or anchors yourself and connect with all the onboard sensors for ultimate control. We provide you detailed tutorials and example files for this.
How does it work?
Our system is very similar to the GPS you have in your car. Like the GPS satellites in the sky, Pozyx requires 4 little anchors to be placed on the walls. The Pozyx board is what you will put on an Arduino to track it.
The full pozyx system (READY TO LOCALIZE reward - power cables not shown)The full pozyx system (READY TO LOCALIZE reward - power cables not shown)
Positioning is achieved by making range measurements (by means of two-way ranging) with the anchors. The Pozyx tags processes all measurements to compute the position and orientation of the board, at a high update rate.
Features
  • Indoor ranging and 3D positioning: Ultra-wideband (UWB) technology is the key to accurate ranging and positioning. However, the UWB-module itself only provides accurate timestamps. We have implemented state-of-the art algorithms to obtain the most accurate ranging and positioning information.
  • Automatic anchor calibration: 3D positioning requires at least 4 anchors to be within range (3 for 2D positioning). In general the position of these anchors must be known in advance. Pozyx provides the feature to obtain the anchor positions with a single line of code. No manual measuring required!
  • Remote control: With the use of ultra-wideband wireless technology, messages can be transmitted over the air. These messages can be text or user data, but also commands to control remote pozyx modules. We made it possible to remotely turn on LEDs, toggle pins, read out sensor data, and much more. Perfect for your home automation project!
  • 9-axis sensor fusion: Pozyx is equipped with an accelerometer, gyroscope and magnetometer. With these sensors it is possible to obtain the orientation of the device. However, separately these sensors all have their flaws. For example, the accelerometer is noisy and the gyroscope is biased. Together these flaws can be mitigated. Pozyx offers 9-axis sensor fusion (3 axes for every sensor) to get the best possible measurements.
  • Reprogrammable: By default, we program the board with our firmware for localization and tracking. However, it is possible to reprogram the microcontroller to suit your own needs. Using the debug pins (SWD), you can load your custom code on the microcontroller of the board. We provide you with detailed tutorials and example files that take care of all the configuration: gpio pins, leds, clocks, and all the sensors (through SPI or I2C).
Technical specs
Technical specs of the arduino-compatible board
  • dimensions: 71.75 x 58.00 mm
  • powerful STM32F401 microcontroller
  • ultra-wideband transceiver (decawave DWM1000)
  • 9-axis inertial motion unit (invensense MPU9250)
  • pressure sensor (freescale MPL3115A2)
  • I2C for serial communication
  • SWD for programming
  • micro USB for firmware updates
  • 4 general purpose LEDS
  • 2 LEDs for UWB connectivity
  • 4 optional GPIO pins
  • Onboard 3.3V regulator: automatic power selection from battery, arduino or usb.
Image of the pozyx tag mounted on an Arduino Uno. (the final version that you will receive will include an usb connection and a pressure sensor not seen here)Image of the pozyx tag mounted on an Arduino Uno. (the final version that you will receive will include an usb connection and a pressure sensor not seen here)
The anchors have similar specs as the tags without the motion unit because the anchors are considered to be stationary. The anchors come in a protective casing of dimensions 63.50 x 63.50 x 22.86 mm and together with a micro USB power adapter.
Where we're at
In terms of hardware, we are nearly finished. We have come from a partial breadboard implementation of our system to the working prototype. Currently, we are finishing an improved version that also includes the pressure sensor and an usb output for firmware updates.
In terms of software, the core features such as positioning, anchor calibration and sensor fusion are finished. However, we still need to polish things and finish the Arduino library. This will be performed during the campaign and during the production of the modules
Why we need your help
Pozyx isn’t a consumer product (yet). It’s a working prototype to show that accurate indoor positioning works! We don’t want to keep it on our shelves. We believe that with kickstarter, we can reach a lot of creative people that can use our positioning system to create the most wonderful applications!
Furthermore, with kickstarter we can:
  • reduce production cost by producing in higher volumes.
  • get feedback while we are finishing our product and writing the Arduino libraries.
Who are we?
Pozyx started with Samuel Van de Velde who has been doing research on indoor positioning for almost 5 years at Ghent university. Because their was no affordable or simple positioning platform available to test his algorithms or applications, he decided to make one. Once the ultra-wideband technology was available, Vadim Vermeiren and Koen Verheyen joined to make the first prototype. After that Michael Van de Velde joined for some serious marketing action.
The Pozyx team: Samuel, Vadim, Koen and MichaelThe Pozyx team: Samuel, Vadim, Koen and Michael
  • pozyx now seems to be a ponzi scheme ;-)
  • We are progressing with SW development a lot and publishing new releases quite regularly:
    http://marvelmind.com/#Download
    There is also FAQ, where we are answering questions and suggesting some troubleshooting to our customers.
    More demos:
    http://marvelmind.com/#video
    John, since you already have our system, your feedback is highly appreciated. Quite often, we are doing even some additional SW customization free of charge, so just let us know what you are missing. We are happy to help with your projects! Just drop us an email: info@marvelmind.com
  • Hello John,
    We are glad to hear that you are happy with the performance of our system (http://www.marvelmind.com/).
    Regarding copters, I can only comment that about 1/3 of our customers are successfully flying copters using our system. What are your particular concerns in regards to copters? We will be happy to comment.
    Additionally, here are a few basic demos we did by ourselves with the copters:
    - https://youtu.be/f_P1luQCsYo - flying indoor (10x5 meters)
    - https://youtu.be/7CZU8tuqTno - flying indoor (10x5 meters)
    - https://youtu.be/0KXyjp-sVTE - flying outdoor (-10C air temperature (not recommended mode, but nevertheless; distance between beacons ~22meters)
    BR,
    Maxim
  • That was my feeling as well.
    They finally got in touch to let me know that they were working on a new firmware upgrade that would solve my problems, but then went quiet again for a month. I don't think they're a real company.
  • Update on my post of 7 July.
    I was just about to place an order for the Pozyx system until I saw Chris' post.   Instead we bought the $349 Marvelmind Indoor "GPS" system  http://marvelmind.com.  This is an RF synced ultrasound system -- a modern version of the MIT Cricket Indoor System  http://nms.csail.mit.edu/cricket/
    The Marvelmind arrived promptly and worked out of the box.  We had it up and running in less than an hour.   Very well engineered hardware and software; excellent user interface.
    The Furman Robotics Club is going to use the Marvelmind package for a flipped classroom study to track an instructor's location in a specially configured classroom layout.  As soon as that project is done we will try it on a quadcopter, but I suspect there may be problems, so we are still very interested in the Pozyx system.
    Chris:  Anything new on the Pozyx resurrection?
  • Pozyx based on Decawave DWM1000 module - http://www.decawave.com/products/dwm1000-module
    Decawave sells evaluation kits http://www.decawave.com/products/trek1000, it can work as local positioning system with 3 "anchors" and 1 "tag".
    It's very interesting is it usable for multicopters. Somebody has an experience with Decawave devices? Or with devices based on decawave chips?
    Until today, they had gone four month without responding to tech support emails, so I had no functioning units (they shipped me two with the same network address). However I got an email today from a new hire who is promising a firmware upgrade soon that will solve my issues, so we'll see.
  • Chris, we are interested in the Pozyx system.  Can you describe your experience with it so that we can understand what you mean by "it doesn't work yet"?  Did it work at all, intermittently, accuracy problems, etc?
    As far as I can tell, the Pozyx team has stopped updating or responding to emails, so I can't verify that it's still a going concern.
