Looks nice, but the plywood doesn't really really match the arducopter frame look.
Also maybe plywood is a bit less crash-proof than polycarbonate.
Do you think it will be possible to cut through it?
And yes, putting gar design on Ponoko will save you a lot of work :)
Simon
Great looking box. Tho Peter I would suggest to use either plastic or stainless screws. One your screws is really close to your magneto and it might affect your magneto readings. Also you should check if barometer is affected.
Simon
I will send some to Chris and he will make it in the DIY shop !!
in Europa i can send it from here
Regards
Peter
I would be interested in one.. if you start a small production.
No sorry ! the Glasfiber in the board is like a optik it burn the Epoxi !
The cost for the Lasercutter = 5000 Euros
