18 QuadroPixel, new generation of frames. Posted by Alexey on December 6, 2013 at 11:42am -up to 17inch props-dimensions of the square 438mm x 438mm-flight weight without gimbal - 2000 - 2600g + gimbal 500 - 1500g-flight time with 15" props and 2pcs 11000mAh maxamp 55min+-price about 600$ E-mail me when people leave their comments – Follow
< $3.00 Silicone caulk and you likely have it water proofed yourself. What you doing - going submarine?
Waterproof it and put me a gimbal for my waterproof case and Gopro 3 Black and I will buy it.
quadropixel X8 mod:
It can fly with canon 5dm2 and 3-axis BL-gimbal
Are the motor mounts pre-drilled?
-if you specify the size when ordering, then yes.
@ Martin Guttesen
"if you rotated the arms 90 degrees, so they were not so flat then you would probably get 5-8% more flight time"
I perfect agree with you Martin.
And also less vibration if flat is vertically, instead of horizontally.
The single reason I would see a horizontally flat arms is when you forward at high speed. But a quad is mainly for hovering.
Very pretty!!!
Looks like it could be made water proof with out to much trouble.
I buy one replacement arm.
Will you show us a pic of the coaxial motor unit in the background?
Looks cool man!
Are the motor mounts pre-drilled? And how do you mount the motors on what looks to be a sealed unit?
