QuadroPixel, new generation of frames.
-up to 17inch props
-dimensions of the square 438mm x 438mm
-flight weight without gimbal - 2000 - 2600g + gimbal 500 - 1500g
-flight time with 15" props and 2pcs 11000mAh maxamp 55min+
-price about 600$
  • < $3.00 Silicone caulk and you likely have it water proofed yourself. What you doing - going submarine?
  • Waterproof it and put me a gimbal for my waterproof case and Gopro 3 Black and I will buy it.
  • quadropixel X8 mod:
    It can fly with canon 5dm2 and 3-axis BL-gimbal
  • Are the motor mounts pre-drilled?
    -if you specify the size when ordering, then yes.
  • Martin Guttesen
    "if you rotated the arms 90 degrees, so they were not so flat then you would probably get 5-8% more flight time"
    I perfect agree with you Martin.
    And also less vibration if flat is vertically, instead of horizontally.
    The single reason I would see a horizontally flat arms is when you forward at high speed. But a quad is mainly for hovering.
    Very pretty!!!
  • Looks like it could be made water proof with out to much trouble.
  • I buy one replacement arm.
  • Will you show us a pic of the coaxial motor unit in the background?
    Looks cool man!
  • Are the motor mounts pre-drilled? And how do you mount the motors on what looks to be a sealed unit?
