  • Think of the Raspberry PI as a potential evolutionary step in the mid range processing power market just like the Arduino was in the low end microprocessor market.  It is bringing real processing power at a very low $$$ cost (along with relatively low weight, small size, and with a small power budget).  The Arduino will never have the processing power to do real image processing or other CPU intensive tasks.
    If you are looking at the Raspberry PI as a straight replacement for what the Ardupilot is doing then you are missing the real advantages it brings to the table.  Sure you could interface it to something like ArduIMU and have a very nice auto pilot but the better use would be expanding the capabilities to image processing / swarm behavior / navigation through complex environments.
    Time will tell if the Raspberry catches on and succeeds or is just blah.  Given that they have already sold hundreds of thousands in preorders it looks like it may be interesting…
  • No extra board needed at all. I2C can be emulated with a kernel module.
  • It's got a CSI connector that will allow a camera module to be supported, but using it also requires writing a driver for each type of camera module. (There's also a DSI connector you could plug an LCD into, if you don't want to use composite or hdmi in a ground station role.)
  • Ok, answered my own question.  Looks like the GPIO pins are accessible. They actually sell a breakout adapter for it on Ebay.  But sadly for a project made to engender "learning" it's very hard to learn and detail technical information about it on the Raspberry PI page.  There's not schematics or even pinouts easily accessible anywhere.  Definitely not in the spirit of open source.
  • Ok, ok.  Sorry for the negativity.  From the technical point of view, one would have to run an RTOS on it.  RTLiniux would be great.  If I could ever get my hands on one, I'd just put my pololu 9dof board on it,  Does it have an accessible I2C?
  • Matt,
    Yes, I agree with you that one can find many high-level applications that can not be performed on Arduino. Vision based obstacle detection could be one of them. I assume, in order to use OpenCV on this card, the only way to input video signal is via USB interface; either using a USB video capture card (such as EasyCap -BTW do you know a better quality video capture device) or directly attaching a USB camera.
    • Is there any other method for video input to Raspberry-pi?
    • Does anybody know if those 26 GPIO pins can be used for PWM ?
    • Can we use GPIO pins for interrupt inputs?
    • Is there an audio input on Raspberry-pi?
  • BTW. It's 26 pin gpio. I'm going to throw one of these on my quad.
  • People are haters, haha.
    It's got 256M of RAM, not 256k. It's also got IO pins, so it could talk PPM if you wanted to go that way, but I'd probably want to plug an arduino or msp430 into the USB and talk serial that way.
    Since it's running linux, you can program with any language you want, such as python.
    It also should have enough power to where you can plug a webcam or two in and use opencv for obstacle avoidance/identification.
  • I'm not a Linux person.
    But how would one develop on this?
    Can it be time deterministic?
  • I find it perfect for low cost whole control system. I'm running my copter with a Fon Fonera 2201 router as brain and Wifi as radio link. (The lack of current stability is for my scratch custom control program :)). It is not all, because router is attached to an IP camera. All those things connected to the same LiPo. With a switched power regulator, there is no problem for too power consumption.
    With that board you will never run out horsepower with a very decent battery life
