The motor stays put. I have another, smaller rocket glider that does eject the motor, but there I mount the motor in the nose. Generally, you want a very forward CG on the boost, and move it back for glide. If you mount the motor in front, you can eject it at the apogee and it does the right thing with CG. The difficulty is that now you have a motor tube in front of the center of pressure, wish destabilizes you in yaw.
With a rear motor mounting, you want to to keep the motor where it is. Ejecting it moves the CG /forward/ for glide, which is the opposite of what you want. I use a "plugged" motor that has no ejection charge.
The motor stays put. Here are some closeups of the motor mount. The original electric motor mount and the new rocket tube are interchangeable. I can swap them in and out in the field.
Yellow stuff is zagi tape--mostly to protect the foam on landing, and to help me to see which side is up. It has a lot more drag than a typical rocket. It's also quite heavy for this motor. For first flight I'm quite happy with a low max latitude :=) I want it to walk before it goes orbital on me. Not sure how much speed the stock airframe can handle before is starts to flutter, strip servo gears, tear off the canopy, etc :=)
Ari.
mhmm, mine seems too much little for an autopilot.
Piloting those things is amazing anyway, isn't it ?
Nice project !
Very cool project !
I was dreaming of such a project 20 yeas ago !
Very nice Ari! I haven't been on RCG as much lately and have wondered what you were up to.
I too would like a video, mainly because I can't make it since I'm on the east coast.
Chris: come to Moffett Field on April 21 and see the next launch for yourself! http://www.lunar.org/calendar.shtml#launches
Ari.
Max speed is lower than i expected. But i guess you will use bigger rocket motor for next launches. Am i right?
What is the yellow coating? kevlar?
Video please!!!!
