Seagull #MAP-X from Seagull UAV !
3689702799?profile=original
      X … marks the spot !
We are proud to present the very first addition to our precision camera trigger family.
Have you ever experienced missing images after a completed flight
 – and having to redo the complete mission ?
Working within Geomapping, Agricultural analysis, 3D modelling or similar – where you capture hundreds or even thousands of images on a daily or weekly basis ?
We have a perfect solution for you, introducing Seagull #MAP-X and optional telemetry ground station !
#MAP-X gives you precise coordinates of photographs taken and only tags the location if the photograph has been successfully taken. On top of that #MAP-X outputs coordinates of failed photographs, giving you a quick data for re-flying survey points and capture the missing photos.
As well as all of the above #MAP-X generates a .kml file for each flight with all of the “Confirmed” and “Failed” coordinates of pictures, which can be loaded into Google Earth for a quick overview after each flight !
With Seagull #MAP-X you get everything you need to connect your camera to your favorite UAV/Drone platform.
Hot shoe sync, servo and camera cables are included, as is also GPS antenna, micro SD card etc. – making it really simple to get started !
#MAP-X delivers unbelievable value to your professional mapping jobs, saving both you and your clients time and money, so you can do more jobs in a day.
#MAP-X is controlled by a standard PWM servo signal from your R/C receiver and/or Flight Controllers like 3DR Pixhawk, APM 2.6, DJI Wookong, DJI A2 – and many others with camera support.
A lot of camera brands and models are supported.
          #MAP-X … improve your workflow !
          The spot is marked ! – now you need confirmation !
With Seagull #TRX you will get live feedback from #MAP-X, adding value to your work by knowing if the mission is going as planned, or if adjustments are needed before a successful flight can be executed !
Do your camera pre-flight sync checks with #MAP-X and have the result shown on #TRX !
Simply connect #TTX which is the telemetry transmitter to your #MAP-X unit, then power up #TRX and #MAP-X. The two units will establish connection and status of #MAP-X will appear on the display of Seagull #TRX.
When “Ready for Takeoff” is displayed on #TRX – you are ready to do Mission Start and get flying !
Get information from your #MAP-X directly to #TRX ground module with the current confirmed photos, failed photos, micro SD card status and GPS lock status on top of that #TRX will display the current trigger mode being used by #MAP-X !
Seagull #TRX is powered through a micro USB cable, and can plug into your PC or a USB power bank and be placed in the desired location for an always easy overview of you current mission status.
          #TRX … saves You and your clients time !
3689702923?profile=original
Intro video for #MAP-X with optional #TRX telemetry kit
We currently offer a 30% discount on Seagull #TRX if purchased bundled with #MAP-X
Visit our shop at www.SeagullUAV.com
If you have any questions don't hesitate to ask – our support is ready to help - have a great day!
Best regards from Denmark,
Rone Scholz-Nielsen
CEO // founder, Seagull UAV
The Seagull UAV Team !
3689674831?profile=original
  • Hi Jason,
    Our development is heavily weighted on feedback - all above is noted !
    Thanks for your input :)
  • This looks great!
    To make this truly a revolutionary product, if it could incorporate RTK GPS or high precision geotagging some how and allow the user to simply put in the % of overlap required (Uses altitude and distance traveled from the GPS to trigger each photo itself) so it could possibly be completely separate from the autopilot system and also allow for autopilot triggering, it could turn any UAS into a survey grade mapping solution with any autopilot system.
  • Hi Greg,
    Thanks for kind words !
    I'm not that familiar with the MX (need to look into that !) but if you have a standard PWM R/C output available, then you're more or less good to go :)
    Regarding the distance triggering - this is not something we have had requested before, and is not a feature we support in #MAP-X..
    Though it will for sure be something we will have in mind for possible future versions of this system ! :)
    What can be defined is the Timelapse interval and the AC-T trigger modes pre-autofocus time.
    And then we have added the option to let it log GPS coordinates on behalf on hot shoe feedback alone - useful for users that want to use in-camera interval triggers, or simply for tagging locations within inspections job sites etc..
  • Looks really good, and probably a better alternative to the 'Camera Trigger' module for the DJI Ronan MX??
    Only just briefly looked at your site, do you have a mode that allows you to set photos taken every X meters? Where you can set X?
