Seagull #REC - New Sony MULTI camera controller !
3689675010?profile=original
Hey Fellow UAV enthusiasts & professionals !
The long awaited Seagull #REC is finally out !
The most affordable and feature rich Sony MULTI camera controller on the market !!
Supporting the latest Sony MULTI (Multiport) equipped cameras !
Seagull #REC is a ‘’Plug & Play” solution and comes with all of the necessary accessories to get you going and capturing!
#REC gives you control over your camera with following features:
 Video record Start/Stop
 Zoom ( 7 speeds in each direction – W/T )
 Autofocus Trigger ‘AF-T’ ( 1 sec pre-autofocus – then trigger )
 Instant Trigger ‘IS-T’ ( instant trigger – as soon as camera locks focus )
 Manual Photo mode ( 2-stage individual focus and trigger )
 Camera On/Off
 Timelapse ( Intervals: 1, 2, 3, 4, 5, 10, 15, 20sec )
#REC is supplied with either a 30cm or a 60cm camera cable to match your application needs !
Check it out in our Shop ->  Seagull #REC
Watch the "Quick Look"
Watch the "Control a Camera"
Watch the "Control a Camcorder"
If you have any questions don't hesitate to ask – our support is ready to help - have a great day!
Best regards from Denmark,
Rone Scholz-Nielsen
CEO // founder, Seagull UAV
The Seagull UAV Team !
3689674831?profile=original
  • NEWWe now offer our newly developed cable for #REC !
    We learned that the standard cable for #REC was a bit hard on gimbals – especially low-powered ones.
    … we listened to you guys – and are proud to present our new ULTRAFLEX cables !
    ULTRAFLEX is as the name states – ultra flexible, and is the ultimate in flexible cable design – perfect for your video gimbal setup !
    The new ULTRAFLEX cables have a cable outerdiameter of only 2.5mm – that’s 2mm less than the Standard cables, we even managed to shrink the size of the MULTI connector !
    3702314756?profile=original
    3702314693?profile=original
  • Sounds great with the A6000 - also very satisfied with mine..!
  • HDMI can also be converted to composite for a fraction of the Price with a cheap HDMI to Composite converter..
    On the other hand - if the digital HD downlink is must have - I believe Connex is still the cheapest solution..!
  • wow nice to bad the nex5 does not work, i'm not about to put my a6000 in the air.
  • you will need connex downlink and the trigger
