Setbacks and Batteries
Well, after playing more with the IMU, the roll gyro has stopped working! I performed a visual inspection of the breakout board, and didn't see any shorts or signs of arcing. I reworked all the solder joints, making sure none of them had come disconnected. Finally, I removed the gyro daughter board from the IMU and tested it on its own, still no luck. The self-test function also is not returning anything, so I think it's stuffed.What a pain in the ass! Just as I was starting to get somewhere with the Kalman. Fortunately Sparkfun have offered to take a look at it and see if they can figure out what's wrong (and perhaps replace it!), as at the moment I can't afford buying any new sensors ($30 shipping every time is a killer!). If I have to buy a new one, I guess I'll have to wait until I have enough cash for a GPS unit, magnetometer and TTL->USB board as well so I don't get nailed for shipping twice.In the mean-time, I ordered some LiPo batteries for super cheap off ebay (E-Fly 2S, 900mAh, 15C), 3x batteries for $10! And only $10 shipping (from Hong Kong). I know what you're thinking.. never buy cheap & nasty batteries, but this is a low-budget project. I'm hoping these batteries will replace the 8.4V 650mAh NiMH batteries that my helicopter has been flying off, and that the weight saving will give me a bit more leeway with my autopilot payload. The only thing that I am concerned about, is that if these LiPos have built-in under-voltage protection (ie. switch off after reaching 3V per cell). Is that standard on all LiPos these days? Being a no-name brand, I couldn't find any specs on the batteries themselves..If I can sort that out, hopefully I can blow the dust and cobwebs of the heli and get some flights going this weekend to re-balance the helicopter and trim it right up.
    Use cheap batteries with a good balance charger, but good batteries may last longer. Check out Hyperion's new Hybrid RS Nano Technology,
    I have a friend who flys a large 10 cell 4500mha pack in a T-Rex 700, He reports that these packs just get warm during a hard flight 110°F, while others pack got very warm 138°F , These can charge at 5C rate and stay cool... I have one Hyperion Nano Tech 1300mha pack for my BlueStik UAV it is working great...
    I had problems with 1st generation Walkera helicopter batteries and chargers several years ago. . Their poor protection devices limit output current and may cause over charging...
    These old batteries were 3 cells 1800mah with 18v charger that the protection board regulation to +12.6v when the protection board fails 18v is applied causing over charge and battery failure , lucky no fire....
    I have many cheaper batteries that perform well, Proper charging with balancer and only discharge to 80% will keep battery healthy...
    I have 2 factory batteries with these circuits running in a new 7"LCD HDTV monitor by Haier, 2200mah 7.4v this pack is current limited for this device. Since it is new and has a internal charger I will trust it...so far so good.
  • I never have had troubles with HobbyKing batteries... I watch them closely upon the first charge, but that's about the only precaution I take.
  • Admin
    Jason,
    The LiPo low voltage cutoff is usually programmed in the ESC. I do not know of any LiPos with built in low voltage cutoff. You might check to see if the ESC in heli can be programmed for a low voltage cutoff. However, you do not want to be in the air when the ESC cuts off the battery power to the motor!
    TCIII
    Unless its all you can afford, just don't fly them for as long as you would have the others and always balance charge the.
  • Never buy cheap & nasty batteries!
