Here is a short video presentation of my Skywalker X8 UAV using 3g broadband internet for video and telemetry.
Onboard my X8 i have this ZTE MF60 3g/Wifi router which handles the communication for the APM2.5 and the Raspberry Pi model B. I didn't wanna use the Dronecell because i will place the load away from the APM2.5. I could have put a 3g USB adapter in my Raspberry Pi as well, but the Pi have more than enough to do transcoding the video-stream, so i use a Cisco Wifi USB adapter in my Pi to communicate with the 3g router and GCS.
The telemetry from my APM2.5 is sent to a Serial 2 Wifi converter which then is connected via Wifi to the 3g router. I then connect to my APM2.5 using TCP from Mission Planner.
The Raspberry Pi are using VLC Player for Linux to transcode the videostream from the Microsoft Lifecam webcamera to a resolution of 352x288 at 500kbit/s and 10 fps. If you want to use the same solution just change the hostname and port to you needs in the command below. I use Dynamic DNS (client configured in my Raspbery Pi) since mye 3g router gets a dynamic IP adress on every new connection.
Command in the Pi for starting videostream:
"sudo -u pi vlc-wrapper -I dummy -vvv v4l2:///dev/video0 :v4l2-width=352 :v4l2-height=288 :v4l2-fps=10 :sout='#transcode{vcodec=MJPG,vb=500,fps=10,scale=1,width=352,height=288,acodec=none}:std{mux=ts,access=udp{ttl=10},dst=mydyndnshostname.domain.no:2000}' :sout-all :sout-keep"
At my GCS i start VLC using this command in a .CMD file to recieve the video from the X8 and re-stream it to the Mission Planner:
"C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" udp://@226.0.1.150:2000 --sout=#transcode{vcodec=MJPG,vb=500,fps=10,scale=1,width=352,height=288,acodec=none}:duplicate{dst=http{mux=mpjpeg,dst=:8080/},dst=display} :sout-all :sout-keep
In Mission Planner you just enter "http://localhost:8080" in the "SET MJPEG Source" when right-clicking the Hud. I have a 6GB per month dataplan in my 3g router and my calculations says that this can give me more than 52 hours of videostream. My sim card is a non-firewalled APN.
For now everything is powered from a MaxAmps 11000mah LIPO This is a high capasity battery and the weight is only 825gram. My plan is to have 2 of those in my X8 for a really long range flight.
Right now i'm using a Sanwa 35mHz radio, but i waiting for my Turnigy 9XR and 433mHz modules from Hobbyking. I don't use 2.4gHz because of the 2.4gHz in my 3g router.
The wiring is directly from the Tx/Rx of the APM to the Rx/Tx at the Raspberry Pi
There has been som changed since this Blog-post so there will be a new blog very soon with my latest configuration.
If you want to do this in Austraiia Telstra do not do public IP addresses any more for non-business accounts. You used to be able to get your APN changed however that is not allowed now.
Beagle Communications will give you an Optus account with a static public IP address for quite a reasonable amount per month.
http://www.beagle.com.au/broadband/mobile_standard.html
No i haven't tried that solution very hard. I tested the Android App 'MAVCell' and it worked ok with a OTG cable.
Hey Tommy I thought you would be the best person to ask about this. Have you looked into just using an onboard phone to update waypoints directly to APM? It seems like it should be easy but I don't know where to start.
Beautiful job Tommy ! I ve just realized how it could be done.
Thanks !
I probably should... But i want the longest flight time and light weight. I don't want to get one empty battery before the other so i draw all power from just one.
correction, mjpg-streamer on UDP via cellular @ 15fps and 640x480 the lowest latency I've achieved 127ms ....
no need to load pi with video streaming, works much better as a 3G/4G router with an IP cam :) I am using Trendnet TV-IP672PI @ 640 x 400 and 15fps latency is about 500ms ..... i think if I change to verizon (currently ATT) and verizon dongle on the other end (currently landline comcast) it will go to 100ish ,, just don't want to sign up for a 2x 2year data plans with verizon... :)
1
2
3
4
5
of 5 Next
