Hi Guys,
The title is a little bit ambitious but i guess no one tried to lift a GoPro with a 140gr Micro Quadrocopter before :D
The throttle was %80 when flying with half drained 2S LiPO battery, this is why it is a little bit aggressive.
This is my micro quadro setup
Controller:Opensource OpenLRS Multi receiver with Gyro and Acc with onboard radio receiver
Firmware: MultiWii v1.9 (modified for OpenLRS onboard receiver)
Frame: MQ-200 microquad frame
Props: HK 5x3 (black/red) props.
ESCs: FL6A Fast PWM 6A ESC (Hobby King 6A with firware update)
Motors: HK 10gr
Melih
nice enough to just get up there take a few shots and come back down. sure beats my smallest fixwing setup that can lift a go-pro
This is really interesting. If you can lift a gopro, you can lift two Panasonic ncr18650b's which could give quite a bit of flying time. This would be a lot of fun indoors.
Another thought, have you tried 3 bladed props to see if you can lift more weight?
Today i was on the field. My quad flew under 15km/h wind without any problem. Setup was same with previous indoor version.
Next mission: less than 100gr Quad with GoPro :)
Yes it is the golden question :)
Unfortunately i didnt fly with full battery to empty yet.
Without GoPro: It flew with 800mA 2S but battery already was 7.4v after 10 minutes . Maybe this weekend i can test the flight time, before i want to remove all extra weights.
With GoPro; It is just for fun but i guess it cant fly more than 3-4 minutes. I will share the results.
Golden question for me, what is the flying time :-) with & without go pro.
I forgot to sharing my first flight video :)
@Flying Monkey: It is UHF(433) antenna but it is working with piece of wire without antenna in few hundred meters
@Juan: These propellers coming with 1.5mm reference hole. I used 2mm drill for changing the diameter first. Then i used very very very(very) small CA drop for fixing it on the shaft.
Hi Melih,
I have one question, how do you attach the propeller to the shaft of the motor? "as far as I can see in the photo, you didn't use the propeller saver"
Regards.
@Flying Monkey,
My setup is 140gr and including 50gr battery + 15gr antenna and connectors, this is less than you suggested :)
OpenLRS Multi board including receiver and controller and weight is only 7gr ;)
I'm using 16gr version(20gr with antenna) of it now, I can remove these extras.
@Jan, Quality 10 times better than tea spoons(gws 5030) :)
But already have a very small balance problem. I balanced all of them with 10x10mm size 3M transparent paper band. And they are very quite and efficent props.
How is the quality of these new 5" propellers from HobbyKing? Are they well balanced? The fake GWS 5" propellers they had before where very very bad!
1
2
3
of 3 Next
