This is some footage shot with the second version of the thermal imaging camera which I tested earlier on (http://diydrones.com/profiles/blogs/testing-a-small-thermal-imaging-camera).
The second version of the camera features a better resolution, an OSD to adjust parameters such as brightness & gain and the possibility to show the picture in false-color.
The camera is very light and small - ideal for UAV applications.
I am planning to shoot some in-flight footage (mounted on my copter) during the next week.
Shot with the 15mm lens:
Technical Details:
Sensor:
Type: (ULIS) Un-cooled FPA micro-bolometer A-Si
Array Size (resolution): 640x480
Spectral Range: 8~14um
NETD: ≤80mk@25℃
Full Frame Rate: 50Hz (PAL)
Power consumption: @12V 200mA
Dimensions without lens:
62mm x 48mm x 48mm (LxWxH)
Weight: 180g
www.diesunddas.co.uk
That would be really nice. I have not gotten my transmitter yet but it should come any day now so I can start testing.
So any details you could share will be appriciated :) I sent friend request to you. (Do not want to take over the comment section with off topic stuff)
Yes. you can connect a video transmitter to the AV Out on the Raspberry Pi. It's actually pretty simple to do. I hacked my own cable, but it wasn't very hard. I'd be happy to share the details with you.
Bill I am curious if you managed to connect a analog video transmitter to the raspberry via the AV out? I am thinking of doing something similar myself.
If anyone is interested, I managed to get the SEEK THERMAL camera to stream via WiFi using a Raspberry Pi 2. I'm next going to try to see if I can connect an analog video transmitter to it for IR FPV. (The Pi has an AV out on it).
This would be the only sub $500 solution for IR FPV that I have seen. On the Pi it can also record to an SD card.
I'm scaling the 204x156 image up to 640x480.
Your post was awesome Felix Meissner. I appreciate it. If you looking for a Thermal Camera for your android phone then visit : http://icodata.de/produkte-loesungen/waermebildkamera/waermebildkam...
> Hope a better company takes them on.
You should probably read the thread before you post...
http://diydrones.com/profiles/blogs/thermal-imaging-camera-competit...
Want to see decent ranged thermals come down in price this coming year.
Having to register to see anything is a bit of a crock. Looks like they selling hobby grade way overpriced.
Hi Euan,
For a more hobbyist oriented solution Check out the SEEK in this previous Blog Post:
The SEEK has 206x156 resolution which is remarkably high for such a cheap thermal camera (way better than the 80x60 of the FLIR ONE).
And only $200.00
Best regards,
Gary
