The BIG Skywalker FPV UAV platform
Skywalker is now in a new version made of EPO foam. Much stronger foam.
Length: 1180mm
Wingspan: 1680mm
Wing Area¡G35.5dm2
Wing Loading¡G36.6
Recommendation
4 x 9g Servo
3S1P 11.1V 2200mAH-5000mAH
Motor: 2215-1200KV or 2815-900KV
Propeller: APC-9045E 9060E
I think this platform could be the replacement for the smaller Easystar if it's possible. What do you think?
Skywalker is now in stock! This is not the EPS foam, this is the new EPO version - much stronger foam.
See more on this Skywalker FPV UAV platform.
  • 100KM
    I found some data on rcgroups:
    3000mAh: 30 minutes
    6000mAh: 50 minutes
    10000mAh: 80 minutes << break even
    12000mAh: 80 minutes << no more benefits
    14000mAh: 75 minutes << starts descending
    From npole's post on http://www.rcgroups.com/forums/showt...h#post18069450
  • 100KM
    Fantastic Andrew - would you say one could fit 2 x 5mAh and push it to 90 minutes plus?
    @Hein, I use a 5Ah 4S battery, and typically fly for a bit over an hour, but I tend to fly pretty gently
  • 100KM
    Well, mine's on it's way!!!!
    Please could someone recommend a battery pack for maximum fly time??
  • Any US source for the Skywalker so there would not be 50.00 shipping for a 100.00 plane?
    Brian
  • I just checked on the site, still says not in stock. I would love to purchase one of these!
    I am in the middle of building a CNC machine to build my own plane designs, but I would much rather skip that step at this time just to get flying again.
    Hooks, let me know.
  • ANy flight reports? If they can bend the wing that much, how stiff is the wing on the Ver 2?
  • Thanks.. .I will take the steps to order one.. any suggestions
  • Dan Smithson
    What I have heard that the Skywalker should be the best FPV UAV platform. and very easy to transport, can carry many equipments, more crash resist, and is bigger than the easystar and will fly safer, longer and higher, should also be very recommended.
  • I am just about ready to put my ardu hardware in a plane...Is the concensus, that the Skywalker is better than the Easystar.... I want the best route...thanks....
