The Quad Rotor Observer (QRO) v6 with a GoPro HD Wide
Here a video of the new Quad Rotor Observer (QRO) v6 with a GoProHD Wide on board.
Flight controller hardware:
KKmulticontroller "BlueBoard" from Minsoo Kim's
( http://kkmulticopter.kr ) and based on the board of Rolf R Bakke
Flight controller firmware:
XXcontroller_KR_v1_4a based on assembly code by Rolf R Bakke converted by Mike Barton modified by Minsoo Kim and Jean-Louis Naudin
- 4 brushless motors 750 Kv RCtimer 2830-14
- 4 ESC 30A
- Lipo battery 3S (11.1V) 2550 mAh
- receiver Corona CR6D 2.4 Ghz
Video Camera:
GoPro HD Wide
More infos at:
http://diydrones.com/?profile/?JeanLouisNaudin
-Aurelio
Here the diagram of the KKmulticontroller board (Jakub version) successfully tested on my QRO v6:
The original ATMEGA 48 on the Jakub board must be replaced by an ATMEGA 168-20PU to load the XXcontroller_KR_1_4a firmware.
Regards, Jean-Louis
Below some various KKmulticontrollers which also works very well on the QRO v6 with the same firmware XXcontroller_KR_1_4a :
Regards, Jean-Louis
Here below a new winter flight mission with my QRO v6:
Winter flight with the QRO v6 and a GoPro HD Wide on board
Regards, Jean-Louis
Here a winter flight mission with my Quad Rotor Observer (QRO) v6 with a GoPro HD Wide on board.
QRO v6 winter flight mission with a GoPro HD Wide on board
Regards, Jean-Louis
High Speed and High Turn flight tests:
Here a new HD video of the Quad Rotor Observer (QRO) v6 with a GoProHD Wide on board.
Regards, Jean-Louis
Here a new flight mission video with my QRO v6 that I have done on January 23, 2011 afternoon:
Flight mission with a GoPro HD on the Quad Rotor Observer (QRO) v6
Regards, Jean-Louis
Hello Chris Cashmore,
Thanks for your comments, here the QRO v6 specs loaded with the GoPro HD camera on board:
Take Off weight: 1062 g (Lipo 3S 2650mAh Turnigy rated for 40-50C with GoPro HD camera)
The Avg Power required to hover at 2 m AGL : 180 Watts
This gives a Power/Weight ratio of 168 W/Kg about 4.5 A peak / motor
Flight time about 9 min
I have previously used Lipo 3S EVO25 2550 mAh rated for 25C, today, I prefer strongly to use Lipo 3S 2650mAh Turnigy rated for 40-50C.
Below the tests results with the Lipo EVO 25:
Regards, Jean-Louis
Very nice indeed!
What kind of total flight time do you get with this setup (with an average speed, not full throttle)? And... What is the total weight of the quad with camera?
Thanks.. Keep up the good work.
Nice video!! I have those motors and ESC, really cheap for the permormance!!!! The best decision I have made :D!
Im designing a CF frame that will look like the MD4 on the arms and motors mounts. The advantage of CF tube on the arms is drag reduction! I wiil be posting my design ASAFinished! If someone knows where I can get a foam with the golfball texture ( Dimples ) please let me know! ;) Im planning to use it on the prop coverage area of the arms to increase laminar flow.
Jean Louis, I like a lot your setup! High performance simple setup! keep it up!
1
2
of 2 Next
