Posted by Gary Mortimer on October 2, 2009 at 9:13am
Still a couple of weeks to run on this round which other than for a few brave souls seems to have proved impossible!Next time lets try and break that Stanford record in 300' steps. If you don't have a clue what I'm on about, watch the video above and listen to the guys from Stanford on the Podcast for some advice.G
Ios, no worries: it's a "virtual altitude" record. The plane flies in circles (within VLOS) climbing and decending between 100ft and 400ft. You add up these 300ft steps until you've hit the record (25 laps)
Can't wait for next month's contest, now with the OBC behind us, I can't wait to get back into it,..but given that we can only operate legally below 400ft (in oz anyway), is this realistic? Also, what about the line of sight thing?
I think the idea is that if you invest your energy in construction instead on formalities, you can get better results. It is normal that unofficial records are so much better, without cheating.
Those FPV types are proving nothing, unless there altimeters have been calibrated.
When I flew up to 30k, our tracking, APRS was in a foam beer cooler with a heat stick broken in it to keep the batteries warm enough to live. That worked.
I thought for the moving map that I could see keeping a laptop in a case would provide enough heat, I was wrong the first one gave up at 22k. The guys on the ground could see though.
I can believe Maynards records, others I see, well.
If they want to get somebody out from the FAI then I will believe it.
Those Stanford guys got the clearances and set a record, they even left an entire 4kgs for the next person to add.
Sounds like an interesting challenge, I am just not sure the weather will allow me to try it out. Will there be any restrictions on the pattern and altitude range we will be flying or we will simply look at the accumulated altitude when climbing? If the objective of the contest is to break the altitude record (without going over the 400 feet FAA limit) then we should not put any restrictions on the pattern (i.e. number of circles, climb per circle etc).
Georgio's is calibrated and he has broken many FAI records.
How will we make contests fair for people entering around the globe, to get back on track?
I have no doubt that systems people have can get higher than the record set.
But I suppose we shall see!!!!!!
What will we do about the seasons in the Northern and Southern hemisphere??
