The perfect anti-vibration foam
3689373678?profile=original
I found the PERFECT foam for the gyros and mags for anti-vibration on the AreoCopter
You all have heard and seen the commercial for Tempurpedic mattress
where the girl jumps on one end and the glass of wine on the other end
that doesn't spill ?
Look them up on the internet and request a free sample. Perfect size and
it REALLY kills the vibration, especially on ArduCopter.
Put this stuff in the Professional housing box under and around the mega and you will be all set.
Earl
  • I don't think it was ever decided 100% one way or the other what "killed Columbia" i.e. foam, or foam & ice, or just ice, or a heat resitant tile. The jury is still out. In any event it wasn't Sorbathane - there is none on the outside of the Shuttle, and it's a soft material. The "foam" used on the outside of the Shuttle (to insulate the fuel tanks) is sprayed on and solidifies rock hard. Sorbathane is a relatively soft & flexable
  • T3
    "Good enough for Nasa cameras on the shuttle, should be good enough for RC models. "
    Is this the foam that killed Columbia?
  • As others have already said - Sorbathan: used tons of the stuff at work over the years.
  • T3
    Surprisingly Velcro straps are not bad for the application.
  • http://www.readyheli.com/Z8006-Zeal-Vibration-Absorption-Sheet_p_36...
    This stuff is awesome if anybody is looking for adhesive vibration tape. I use it to mount my APM.
  • Edmunds Scientific's sells 1/8 x 12 x 12 Sorbothane sheets for $19.95
    Remember: A bad design can actually make things worse for vibration damping.
  • "There is a product called sorbothane"
    Funny you should mention it. I was just reading about sorbothane.
    http://en.wikipedia.org/wiki/Anechoic_tile
  • I would suggest a bigger problem than static might be retention of moisture in the foam causing corrosion of components and connections on boards in contact or near the foam. Also, foam makes a great insulator so heat build-up could be an issue in warmer weather if components are surrounded by foam.
    There is a product called sorbothane, a foamlike rubber product, I think that could be used to make vibration mounts. Also there are dandy vibration isolators in different sizes used to mount hard drives and other components in computers.
    @phill - i think you're right. APM outputs 5v so probably need one of these level converters:
    http://www.sparkfun.com/commerce/product_info.php?products_id=8745
    @Earl - the foam is a bit thick. I wonder if they have it in thinner strips. For the traditional heli we need about 1cm ~1.2cm thickness. PM me if you know of a good source and we will add it to the parts list.
    vibration is a super big deal (although the current OilPan gyros are a lot beter than others I've seen).
    Any idea if magnetometers are actually affected by vibration? I don't see why they would be actually.
    One last thing - the latest arduCopter code allows you to set the magnetometer orientation. The above shown orientation would require a change to one line of code as mentioned on the wiki. Look for "setOrientation" here.
  • i hope you regulated the volt pin on the magnetometer. as its 3.3v the board puts out 5v
