A semi-autonomous civilian UAV system designed for hunters and fisherman. The current
project is called The VULTURE System (Versatile Unmanned Lingering
Terrain Utilization and REcon ). It will be used to help hunters and fisherman find
game and schools of fish as well as to find the best areas to hunt in and paths to take.
The user will be able to unpack the system take off vertically and look at the view from the air and then circling areas of interest until the hunter, fisherman or team of eithar can reach the location. The system is not designed to be ultra portable from the ground, but more with someone dedicated to ground support at camp or on a boat to guide the team.
Key
Features:
VTOL Capabilities
Long range communications
Long flight duration (<30 minutes)
Autonomous loitering abilities
Waypoint navigation and return to user in the event of not receiving transmissions
Infrared camera for finding game, schools of fish and night time recon
Initial testing of certain functions will be done on a SkyHawk powered glider
Final testing and platform will be a modified Predator pictured above
Sorry Gary, did not realize I was breaking the rules... the purpose of the picture was just that it was my last project, I was trying to show that I complete things as someone was trying to imply I couldn't follow through with what I say.
Original Post (Edited)
Lew Payne -> sure do that..... lol
Sgt Ric ->vI achieve the un-achievable, I am 28, I own my own business and only work about 20 hours a week. Before I started my business I had a lot of nay sayers and know one took me seriously. I am looking into selling my business in six months to receive a lump sum, into which I will inest my ideas into inventions and innovations as well as a new local business. I have already spent a good chunk of change into the project, and anything I spend my money investing into I follow through with b/c I have worked so hard for it and to get where I am at in life right now. I have the time and capability to do this. I am waiting for a lot of parts ordered to be coming in the mail then you will see more progress reports in this blog. This weekend I went and met an old r/cer from craigslist and bought about 20 airframes, ducted jets, servos, 3 nitro motors, 3 Rx and 2 Tx, as well as a lot of other parts. I have a huge field behind my house and garage full of tools as well as great mechanical knowledge and some software and electronic knowledge. My point is, never underestimate someone when the name of the site is DIYDRONES.com, anything relevant goes.... I will keep everyone informed of progress, My last project, certainly not as complicated but finished and me my old lady and step son get alot of use out of it->and bGatti, thanks for the cheers!
Nicholas, good luck with your project its certainly ambitious.
Without wishing to sound too much of a prude I would ask that you remove the image of the rifle. I'm not sure quite how it fits into the subject matter.
There is a policy of not discussing military applications here, the odd thing gets through but we try and keep it that way.
I refer you to this point in the site policies.
6) No discussion of military applications of UAVs. This site is just about amateur and civilian use.
I realise that rifle is not for you UAS.
The rest of the rules are here
http://diydrones.com/profiles/blog/show?id=705844:BlogPost:17789
Thanks Gerry for your positive input!
Yes you understood correctly and I was wondering the same thing about using the alternator as a starter, I believe it should be possible.
I also plan on starting on the power plant, after I modify the airframe to fit. I also just received e-mails from the distributors saying that both my planes had shipped today! So I should be able to start work on the project within the next week or so.
I may find out through development that there is a better airframe to suit my needs as you are saying. And regardless if I finish with the Predator successfully I do plan on incorparating the platform into different airframes such as hand launch and maybe quadcopter.
Thanks for your input and best of luck on your projects as well!
Everyone loves videos so I can't wait to see your progress come along. If I understood currectly it sounded like you are building a hybrid vehicle from a glow engine and (?brushless?) alternator? I just bought an AP Hornet .09 for the same goal. One of my priorities is to install an electric starter possibly using that same motor as the alternator.
I normally like to design starting with the power plant/engine and build from there. But if you've got an airframe in mind you can start with that and work in the opposite direction as well. The platform looks flexible enough to accommodate without stifling your creativity.
The military uses multiple UAS to fill different roles, just like there are different firearms for different applications.
If you end up having to split some of your desired features off in to a seperate plane, complimentary systems can often do more than a single multi-purpose device.
Man portable hand launch platform may remove the need for VTOL in primary vehicle. Etc.
Best of luck and hope you upload videos of your subsystem tests as you work on them.
Best Regards,
Gerry
We all have great dreams, but in public we keep it to what is achievable.
1
2
3
of 3 Next
