  • Thanks Fab !
  • Awesome
  • Hi Fab, What radio TX u r using ? pls elaborate flight phases
    I'm using the DS-16 from JETImodel. Here some pictures (flight phases, function curves, logical switches):
    3701788254?profile=original
    3701788163?profile=original
    3701788263?profile=original
    And yes the transmitter can make screenshots :-).
  • a lower channel controller?
    Very interesting question. You can use an arduino and program a copter switch.
    and it repeat the signal to your main exploring/fpv copter so if it went behind an object the signal stays intact.
    Mega FPV flying with repeater copter... :-).
    We need to revisit swarming and bake it into the GCSs a bit better.
    ArduSwarm ;-).
    Love this! We need to revisit swarming and bake it into the GCSs a bit better. Right now it's just in Mission Planner and is a bit of a hack. But I think as we move to long-range BT and WiFi control, it will be easier to do point-to-multipoint control in APM Planner, which is built on a multi-UAV architecture.
  • I saw this similar on another thread, made me think that you could send up a signal repeater on the first copter, to hover with a nice view over a complex terrain (hills,trees) and it repeat the signal to your main exploring/fpv copter so if it went behind an object the signal stays intact.
    -P
    -P
  • Since auto mode kind of locks out the controller input, isn't there a way to do this with just modes? i.e.: a lower channel controller?
  • No it's the DS-16 from JETImodel. A very nice controller...
  • What controller is that? Its not the fabled Horus is it?
