Hello
wr703n.jpg?width=750
I found that lot of people discovered this new feature of the wr703n flashed under openwrt : It is able to stream an USB webcam (soon a Gopro using an easycap) and also to make a bridge between a serial interface (USB according to CDC driver or 3.3V TTL).
see : http://www.diydrones.com/profiles/blogs/hacking-a-rc-helicopter-for-wifi-router-control
Here is the tutorial (3 parts + 1 part unbricking ;) ) on Openpilot Forum : http://forums.openpilot.org/blog/52-fertitos-blog/
So I started a TUTORIAL to help those that would like to add this feature on theyre drone and start developping new sensors :
I'ld like to work on a laser line avoidance system using the webcam :
If you have question... ;)
  • Hello,
    I'm planing on using openCV to do some calculation (3D scaning, movements, ...).
    when I'll have time... :D
  • This is very cool.  I think the TP-Link uses the AR9331 SoC which is a pretty good little system.  The company I work for sells a product based on that chip.  The only thing you will run into with this is that it is a 1x1 802.11n chip which means that it will use more airtime to send data.  One tip, keep the radio in 20MHz mode, the Tx Power will drop by 3 dB if you put it in 40MHz.  Good luck to you on this and I look forward to seeing the results.
