If you're using the UAV DevBoard with Futaba equipment or any other modern RC gear that outputs servo voltage of less than 3v, you're going to need a servo amplifier (also known as a booster or buffer) so the autopilot can reliably read your signals.
You can buy one from a commercial supplier like FMA for $15, or you can use our dual optocoupler and save yourself $10 for each pair of servos you amplify.
Out of the box, our optocouplers are designed just to clean up the RC signal, which is handy if you've got RF noise messing with your RC system. But if you solder two rails on the board (shown below), they become a very effective two-channel servo amplifier.
Make sure that the "input" side goes to the RC receiver and the "output" side goes to the servos or UAV DevBoard, like this (servo option shown):
When you're done, the servo amplifiers will take any input voltage and output a healthy 4.8v. Here's my scope data, from a Futaba FASST 2.4 Ghz system.
Before amplification:
Is there an updated link to the store on this one? this thing would be good for using some of the large 5V servos that do not work with Futaba or Pixhawk.
Great Idea.... After seeing this I realised I could use an opto coupler to convert 3.3V TTL serial to 5V TTL serial for a GPS output. This method could use 2 resistors and a 6 pin Optocouler.... I currently use 2 transistors and 4 resistors to do this. This idea could also be used for a TTL to RS232 line converter (once again 2 or 3 components ) - beats using a Max232 line converter and all the associated components.
Thanks for the Great Idea Chris!
One more thing, just to be clear: The booster connects between the Rx and the UAV DevBoard.
You do not need a booster between the UAV DevBoard and the servos, that interface is just fine. The DevBoard output voltage is nominally 5 volts.
Best regards,
Bill
Thank you very much for this posting this information. Its a great idea.
Best regards,
Bill
