UgCS 2.1 is out!
3689630370?profile=original
I am pleased to inform that UgCS 2.1 is out now. All versions including UgCS One are available.
There is of course UgCS Open which is free and will suit needs of most of hobby users who fly drones for fun.
With UgCS version 2.0 one has ability to search for locations via text search and our new 3D map engine supports different sources of maps. Custom map sources can be added in configuration tab of the software.
We have retained multi drone support even for Open version thus you can work with scenarios involving multiple vehicles.
UgCS runs on MacOS/Linux/Windows and supports most of popular autopilots such as 3DR AMP/Pixhawk, DJI Naza(Phantom2)/Wookong-M/A2, ARDrone, Mikrokopter
Here is full list of changes from 2.0 to 2.1 http://ugcs.com/release-notes
Thank you,
UgCS Team
  • Rick, we tested how UgCS works with UDP, RTSP and RTP transports. It works ok. For example, i run rtp stream with help of ffmpeg:
    ffmpeg -f dshow -i video="USB Video Device" -vcodec libx264 -tune zerolatency -b 900k -f rtp rtp://127.0.0.1:1234
    To read from rtp stream you need to create .sdp file, something like that:
    v=0
    o=- 0 0 IN IP4 127.0.0.1
    s=No Name
    c=IN IP4 127.0.0.1
    t=0 0
    a=tool:libavformat 56.1.100
    m=video 1234 RTP/AVP 96
    b=AS:900
    a=rtpmap:96 H264/90000
    a=fmtp:96 packetization-mode=1
    Then add to vstreamer.conf link to sdp file by adding input stream configuration string
    vstreamer.inputstream.0=RTP_Stream_Name;c://test.sdp
    vstreamer.conf is located in "c:\Program Files (x86)\UgCS\bin\" folder. Don't forget to restart video-service (or server) after config changes.
  • Alexei, you say you have support for H.264 network streams. So far we have been unable to get a Wi-Fi based stream using UDP/IP RTP container using H.264 codec to work at all without having to transcode the video MJPEG which is a very slow process and makes it almost unusable. Can you provide specific instructions on how we can make this work with minimum latency. We are using gstreamer currently.
  • Fnoop Dogg, yes, thank you, detected the issue. I'll post a comment when we'll fix it.
  • Dan, yes we do support h.264. In general we can work with network streams and streams from devices connected to USB. If you experience any problems with video please tell us you video encoder type.
  • Doesn't support latest ubuntu unfortunately so I can't test it.  Looks good though from the screenshots!
  • Thanks for this, I will download the free one and give it a try with my 3DR X8
  • Janis, does UgCS have the ability to receive H264 video streams?
  • Great work! cant wait to see the changes from the older version I have
  • Hi,
    You can setup your own map sources or use ones you have bought commercially. Locally hosted Geo map server is also an option.
    Our map engine caches maps by default. Cache is limited by size, default is 1GB. It can be changed in map.xml parameters file.
    Here is screen from options to set up map sources:
    3701894505?profile=original
  • Hi,
    Firstable very nice work ! It's a nice GUI with a lot features but it seems easy to use.
    Can I ask from which sources the maps come from ? Can we use the ground station even offline and still have the tiles ?
