Hey, guys,
We just wanted to inform you that the new version of UgCS ground planning software for drones has been released and packs a ton of great new features and improvements.
- To offer UgCS to a broader commercial market the support for YUNEEC H520 drone has been added. Support for MavLink2 is added to grant higher flexibility and security to MAVLink communication.
- Added operations to mission editor provide more flexibility for drone mission planning, enabling to convert route from already calculated into editable waypoint route for single waypoint adjustment; to split route manually or by distance into separate routes or to merge several routes into one and to invert the route.
- As demonstrated in UgCS CSV/KML data import tutorial (https://youtu.be/C9_AaaNaj6Q), the upgrade of import functionality enables to import KML files not only as “Area Scan” or “Photogrammetry” but also as “Perimeter”.
- UgCS for DJI update improves the connection and video transmission to UgCS desktop, added manual focus option for DJI X5 camera and Airlink configuration settings.
We've also expanded into the field of drone command centres with UgCS for command centres.
UgCS for command centres enables effective UAV integration into emergency and security command centres. UgCS and drone usage during dangerous operations or at hard to reach areas provides a live preview of the situation not only to personnel in-field, but for officers at the command centre. This enables more precise situation assessment, decision making and effective management of first responder teams, providing more efficient resolution of disaster situation or even saving lives.
UgCS centralised drone management solution enables command centre operators to track on the map real-time position of the drones used in-field and receive live video streams. Command centre operators can mark points of interest on the shared map to indicate locations for field drone operators for detailed inspection or even can take manual control over the drone and its camera.
Get the latest version of UgCS here: http://www.ugcs.com/download
Discover the UgCS solution for Command centres: http://www.ugcs.com/ugcs-for-cc
Safe flights,
UgCS Team
