Uhm.. another GCS???
"3689379691?profile=original
Uhm yeah hi, I'm ZQ, long time lurker, first time poster..."
Well, this is what happens when a recently graduated grad student gets bored, likes aviation and is trying to learn a new language/framework. So, here's some looks at a GCS for APM written in... *shudder* Adobe Flex 4. Before I get slammed, the only reason I'm writing it in Flex 4 is because I'm planning on using it for some other projects and need to get used to it, plus with Adobe AIR, it can run on desktops. (That and I have a slight aversion to C++).
The instruments are configurable (e.g. you can change the speed ranges on the ASI, etc), and it uses google maps for the waypoint system. It'll support (eventually, once I finish writing it) all the commands present in the APM command list. Communication can be done over serial, with the use of serproxy (as Flex/AIR doesn't have access to a serial port directly). I'm also planning to add a vertical profile plotting capability to the GCS, but that will come a little bit later.
Additionally, I whipped up a GPS/IMU simulator in Flex as well, to test out the packet communication and position plotting on the GCS. The simulator allows you to plot waypoints, and select an update rate, and it will broadcast position, speed, altitude and IMU information in APM binary format over a network connection. You can also connect multiple clients to the GPS Simulator and they'll all get the same information.
So without further ado, here are some screen shots, and I'll update more shortly (and put up .air packages if there is interest).
GCS Screen (Still a bit empty right now)
GPS Simulator
What happens when you want to see interesting patterns
Installation Instructions:
Download the .air files from:
http://zhiquanyeo.com/apm-gcs/APM_GCS_GPS_Emulator.air
http://zhiquanyeo.com/apm-gcs/APM_GCS_ControlStation.air
You will need the AIR 2 runtime available from http://get.adobe.com/air/
Usage:
Start up the waypoint simulator and click to add waypoints. The delete and add before/after functionality doesnt work yet (oops). You can click on a waypoint on the map or in the list to select it and change the altitude. Waypoints are draggable on the map.
When you are ready for clients to connect, enter the port number you want in the textbox and click "Start Listening"
Start up the GCS and set up the correct port number in the box. Then click connect. You should see "Connected!", otherwise check your port settings. Then click "Start Simulation" in the GPS Simulator and watch the fun happen.
Note: The menus don't work, and things might be prone to breaking (cos.. you know, grad students are horrible coders). If you find any bugs or crashes, let me know and I'll add them to my (ever-growing) TODO list.
  • Sweet. Adding waypoints by clicking on the map is a great feature.
  • Update coming sometime this weekend (hopefully). Adding in waypointing for the GCS, and you can add waypoints before/after, or by clicking on the map. Also adding export capability to a WaypointWriter style file.
  • As simple as your app is, yours is the first one of all GS I have seen working. Please keep working on it.
    Good start! Please do post the .air files.
