3689592957?profile=original
Dear Friends,
today we finish to test first prototype of micro brain , this is the video of first power on , all work fine , we check all onboard sensor : IMU , BAROMETER  . Check eeprom for parameter storage and SD card. Serial port , and usb interface . All work fine :) Check also new bootloader and our mission planner fork with VRBrain support all work perfect . Diego our Electronic Designer doing a great work no error until now :)
Today 09/05/14 finish the test of all subsystem : Magnetomer , GPS , RC IN PPMSUM and RC OUT and all work fine . See the video .
These are the specification :
CPU STM32F4 VR OS based on NuttX kernel 7.1
1 EEPROM or FRAM device for parameter storage.
IMU MPU6000 SPI.
MSIC Barometer 10 cm resolution.
8 PPM Radio RC Input .
8 PWM ESC - SERVO Output.
1 SBUS Radio Input compatible with Futaba SBUS and Spektrum ,too
1 SBUS Servo Output.
SD Card Reader until 64 Gbyte.
1 RGB LED
2 LED Output
1 Buzzer Output
On board telemetry module availabe at 433 / 868 mhz. (option)
connector for external 3DR/VR GPS + MAGNETOMETER
dimension : 3.2 x 3.2 .
weight : 10 gr
3689592857?profile=original
Price is 99 euro the board pre order is open the mass production start in 1 week when finish the test of first production batch .
more info about status of the product  on the store: http://www.virtualrobotix.it/index.php/en/shop/autopilot/vrbrainmicro51-detail
APM Copter , Plane , Rover Firmware available and fully tested by our devteam.
official blog post : http://www.virtualrobotix.com/profiles/blogs/vr-micro-brain-5-1-is-alive-first-power-up-and-os-check-up-fantas
for more info send a mail to info@virtualrobotix.com
Best
Roberto
  • Board looks really nice Roberto,
    Does it have installed OTP certificate so it will work with off the shelf Mission Planner?
    Best Regards,
    Gary
  • So this is a full small sized substitute to Pixhawk? And the mission planner works just fine?
  • Ok i stepped into the Vrbrain 5.1 and pre-ordered a board. This will be a good fit for my Ecks 230mm frame. I will let you guys know how it turnes out when it comes in.
  • Any news about the next vrbrain?
  • HiNoli, maybe a belt drive version is better if you want to use RTL function. Less problems with tailstrike.
  • Hi Roberto,
    >>What kind of Hely are you plan to use with our autopilot ? Do you have experience with other board ?
    I am planning to build one using this helicopter kit:
    HK-550TT 3D Torque-Tube Electric Helicopter Kit
    http://www.hobbyking.com/hobbyking/store/__32410__HK_550TT_3D_Torqu...
    Probably you should build one helicopter phototype using this kit with VR micro brain 5.1.
    We are using APM 2.6 on fixed wing UAV at the moment.
  • i am more interessing by the vrbrain 5.1,i hope it will be available soon
  • Hi Roberto.
    Please PM me as soon as these are ready for purchase.
    Thanks.
    Hi William,
    sorry , don't worry send us a mail to info@virtualrobotix.com i see your order cancelled on store send us your  address so we can check what kind of probblem do you had on then store and help you to place a pre order :)
    In these hours we have a lot of request i think that our new platform like a lot :)
    Best
    Roberto
  • Guys,
    Just tried to place an order for five units but the automated checkout did not like my US address. Any help on how I can get these ordered would be appreciated.
    Bill D.
